what are the 335d tuning options?
07-01-2009, 01:18 AM | #1 |
Rep 93
Just came back from test driving the 335d. It was great....for a diesel, but performance wise I wasn't that impressed. What are the current offerings for performance sw and piggybacks? What kind of wheel hp/torgue numbers can these engines produce with a tune?
07-01-2009, 04:39 AM | #2 | |
Bodhisattva
14
Rep 181
*ECU flash *sprintbooster *sporty air filter Unfortunately US 335d are tuned down in comparison with European ones because of restrictions on emissions. Not to mention the fact that 335d's Steptronic never launches in first gear unless you use it in a manual mode. That's why the 3 options above are not options, they are a "MUST HAVE"
Salut, Gilles! 335I E92 6AT - V3.2 - GRUPPE M - FMI - RR DOWNPIPES - AE EXHAUST HFC |
07-01-2009, 05:11 AM | #3 | |
Moderator
322
Rep 5,493
There are one or two piggybacks available, but the best solution is by far the ECU flash. Some threads for you to browse: http://www.e90post.com/forums/showthread.php?t=174545 http://www.e90post.com/forums/showthread.php?t=113581 http://www.e90post.com/forums/showthread.php?t=263369 http://www.e90post.com/forums/showthread.php?t=254282 http://www.e90post.com/forums/showthread.php?t=253564 http://www.e90post.com/forums/showthread.php?t=155537
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
07-01-2009, 08:40 AM | #4 |
Rep 12
hey
now have been on dyno two times. firts time try to get so much out as can with DPF. results are: about 320-325hp and about 660nm.can get more but then DPF start get dirty very very fast.so i do not beliewe some countryes cars have so much power with DPF.maybe get little bit more=more shit to DPF and dyno shows more than here... second time DPF away,3inch downpipe. 361hp and 780nm.now propblem is boost start increasing itself after 3000rpm=wastegate too small. next: have to increase downpipe size to 3,5inch and exhaust pipe to 2x2,5inch. port westgate. this way could get broken 400hp.torgue to higher rpms maybe also more.not down because gearbox. Greetings Pasi from Finland |
07-01-2009, 08:54 AM | #5 | |
Rep 1,184
changing parameters after every hardware change? |
07-01-2009, 11:09 PM | #6 |
Rep 12
