      09-03-2009, 05:23 PM   #1
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
BMW Performance Intake Kit for 130i now fitted!!!!
As some of you will already know, I've been treating myself to plenty of goodies of late and spoiling myself somewhat!
Got my BMW Performance Intake delivered and I installed it today also
I've been looking for reviews on this Intake for some time and there haven't been many and none which could convince me to part with UK £570+ for one but an opportunity came along at a price I couldn't refuse!
To be honest I wasn't expecting very much, especially after I opened the box and looked what was inside. It just looked like the same but with Carbon lid on. The filter as mentioned before looks like a K&N type and there is a replacement lid (uses the same box) and a small intake which takes additional air from the bulkhead!
After closer inspection you can see from these pics that the twin air inlets are the same size as the old one but the divider is in a different position
The connecting pipe is much larger though as seen below
and the lid
here's a picture of the smooth lid compared to the old one
picture of the extra inlet that now leads to the bulkhead which replaces the plastic piece
New K&N style filter
The installation for extremely straight forward and took around 30 mins. Not bad considering I had no installation instructions and also that I'm not the best DIY'er.
Now the juicy stuff!
I started the engine with the bonnet open and immediately, I could hear the induction noise. I give it a few blips and to my surprise, I could hear a difference
Closed the bonnet, into the car and the sound was a little muted at idle, thanks to the good sound insulation of the 1er. Drove away slowly and that's when I thought it was as expected. No difference than before from the inside, windows shut.
I decided to give it a little more of the throttle, in gear and suddenly the Intake comes alive! Not much sound below 3k revs and then suddenly the Intake noise comes rushing in! I dipped below 3k and again just like before but as soon as you hit 3k revs it's almost like some valve has opened up and the sound is very noticeable, even with the windows up. I'm liking it!
Now engine warmed up, I decided to find some nice back roads where I recently had a blast in the 135i and also in mine prior to Intake and now I'm really on it and all I can say is WOW!!!!! The induction note put a grin on my face that I was just not expecting and adds something to the soundtrack that simply not there before!!
At this point I wound the drivers side window down and the sound just magnified!! I recently test drove an M3 CSL and I would honestly say that some of the characteristics are there but not as extreme and a little more muted!! This I was not expecting but I had to wind the window down to get the maximum sound track.
The disadvantage (or advantage) of the 1 Series is that it has excellent sound proofing and like the BMWP exhaust you get the most from it with the windows down. Although you can hear the exhaust and Intake in this case, it is well insulated but you can definitely still hear it!
It also felt noticeably faster, although to be honest I'm not sure if this was a placebo effect or perhaps caused by the condition of my previous filter which was rather dirty after only 13k miles!!
It may or may not produce big gains on the Dyno but the subjective feeling of greater responses and more power are definitely there just like the same impression when I changed the exhaust!
My conclusion to this upgrade is that I will say it's every bit as good as the BMWP exhaust upgrade and adds it's own personality to an already great sound track and I whole heartedly recommend this to anyone. Remember, this is coming from a sceptic of this product!
To be honest, I'm rather shocked that some similar bit's of plastic and a new filter can make such a dramatic subjective difference
Early days I know, perhaps the novelty will wear within time but I will post again after spending more time with it.
2018 BMW E87 M2
      09-07-2009, 03:46 PM   #2
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Picture of mine installed
2018 BMW E87 M2
      09-07-2009, 08:01 PM   #3
dontask
Australia
13
Drives: White BMW 135i
Wow guys, that looks awesome. I'm wondering how hard it would be to modify a stock intake and add a K&N filter?
Modded 135i
RHD Bumblebee
      09-07-2009, 08:45 PM   #4
Hind
///Mmmm
Drives: '09 BMW 135i
Very cool, congrats.
Current: E90 LCI 335i JetBlack - BMS OCC, JB4 w/ E85, ETS Charge Pipe, Vishnu Catted DP
Retired:///E82 135i LeMans - 12.710 @ 108 MPH
Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMS DCI, BMW Perf Sideskirts, BMS 12/10 Spacers, E93 Front Sway
PDC Flickr YouTube
      09-08-2009, 03:09 AM   #5
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
It maybe that the BMW Performance filter can be purchased separate. Could be one of the below is part number
2018 BMW E87 M2
      09-08-2009, 06:03 AM   #6
jkp1187
Unindicted co-conspirator
Drives: to work, mostly.
Thanks for posting this, always wondered what the differences were.
When you say there's an additional small intake that 'takes air from the bulkhead', do you mean from the fenderwell?
Interesting that the factory orange filter looks almost the same as the new filter.... Wonder if it would be a straight drop-in replacement?
      09-08-2009, 10:17 AM   #7
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
You can see it in the picture that the lid now extends to the corner where there is a small hole which leads to the area where below the wipers are.
Yes it's a straight swap as the original airbox is retained, at least on the 130i that I have. I believe the 128i air box is a little different so I would check yours first.
2018 BMW E87 M2
      09-08-2009, 08:31 PM   #8
dontask
Australia
13
So is the new BMW Performance filter an oil type filter that can be cleaned? Or is it the standard paper filter?
Modded 135i
RHD Bumblebee
      09-09-2009, 12:28 AM   #9
type one
Drives: 130i
Thanks for the excellent review, I am going to speak to my BMW dealer to get a price now ! ... better prepare myself to part with some serious coin...
... just priced it up from my local BMW dealership... AUD1700... that doesn't translate to 400+pounds...
      09-09-2009, 01:24 AM   #10
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Is the below the part number you got quoted on?
http://www.realoem.com/bmw/showparts...80&hg=13&fg=95
There must be some mistake!! I can't believe that it's more than double the price!!
It would work out cheaper to buy in UK and export to Australia for cheaper!
Looks like an oil type to me.
2018 BMW E87 M2
      09-09-2009, 01:34 AM   #11
type one
Drives: 130i
yup exactly the same one... don't forget we are in Aus so we get a mark-up for being on the other side of the world and another mark-up to make up for less demand on such product.
and yes it will work out cheaper so i am asking a friend of a friend a favour to find out the exact cost for me and then a cost of shipping...
      09-09-2009, 02:22 AM   #12
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Try emailing Kevin at Cotswold BMW for a quote. They are a BMW dealer in UK that is widely used on babybmw.net forum.
kevinandrews@cotswoldgroup.com
2018 BMW E87 M2
      09-09-2009, 05:27 AM   #13
type one
Drives: 130i
Thanks!
      09-09-2009, 06:17 AM   #14
///Mike135i
England
Drives: E82 M 135i
Nice write up Sooty, real shame this isnt' available for the 135i.
I put a Dave F (KnN based) system on my M3 Evo and it used to make the most wonderful noise. Made me feel like I was driving a race car. In fact I still watch videos of my Evo on the ring now and again just to have that sound back in my life for a short time
Really pleased for you, your car is shaping up very nicely indeed.
      09-09-2009, 06:35 AM   #15
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Thanks Mike. I had a M3 Evo also some years back which was a great car.
I read somewhere that BMW were having problems manufacturing one for the 135i that gave any gains over the already very efficient std. one.
The Injen ones here seem very popular but I assume losing warranty is all part of the question to whether people make changes or not.
The car is getting very close to how I want it and I would go as far to say I prefer it to both my previous M3's E36 & E46 which is a bold statement indeed!
I'm ordering the BMW Performance Brake kit very soon as test driving a 135i has shown how much more feel the brakes are compared to the 130i. The brakes on the 135i are even better than the E92 M3 I recently drove also!
2018 BMW E87 M2
      09-09-2009, 08:20 AM   #16
jksgoh
jksgoh's Avatar
Australia
141
Drives: M2
2008 E82 125i  [0.00]
Any chance of uploading a sound clip?? Can't seem to find a decent on the net
      09-09-2009, 08:57 AM   #17
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
There's a video here albeit the guy is Dutch with English subtitles
http://www.bmwblog.com/2008/11/16/vi...-parts-review/
2018 BMW E87 M2
      09-10-2009, 01:01 AM   #18
jksgoh
jksgoh's Avatar
Australia
141
Drives: M2
cheers thanks for the link
      09-10-2009, 02:40 AM   #19
dontask
Australia
13
Gruppe-M imitation
Also found this Gruppe-M imitation from an Asian ebay supplier. Looks like they took a Gruppe-M and copied it exactly.
I'm thinking that the BMW performance is still better, since even the original GruppeM still reuses some BMW (non performance) OEM parts and has a baffle to the airbox. I like how the BMW performance intake has enlarged inlets and no baffles.
That being said, I prefer the K&N filter over the one BMW performance offers.
But, the reality is that the difference might only be a few ponies, since the BMW performance intake with exhaust only nets about 10hp total.
This costs $480US on ebay, but we might be able to get him down further if we order a few. Group buy anyone?
Modded 135i
RHD Bumblebee
      09-10-2009, 03:00 AM   #20
sootyvrs
sootyvrs's Avatar
35
Drives: BMW M340d
Perhaps this may interest you
http://babybmw.net/forum/viewtopic.p...9&hilit=simota
2018 BMW E87 M2
      09-10-2009, 07:15 AM   #21
dontask
Australia
13
interesting...thanks for that thread!
i think the difference is that the one I've shown is Gruppe M knockoff, whilst the one in the thread is a "Simota".
Also found this:
http://www.babybmw.net/forum/viewtopic.php?f=20&t=4949
Modded 135i
RHD Bumblebee
      09-13-2009, 06:10 AM   #22
type one
Drives: 130i
thanks to Sootyvrs, my BMW performance intake is on the way from the UK! very happy...
1addicts
