18X8 225/40/18 18x9 255/35/18 Will fit in 325i 2006 Premium Package
09-08-2009, 05:41 PM | #1 |
Rep 51
New to this forum and need help. Just brought 2006 BMW 325i with Premium Package. I want to buy a set of wheels n tires from a friend. He has 2005 330ci. The size of the tires is: 18X8 225/40/18 18x9 255/35/18. Will these fit in my car? any suggestion or recommended to made the car look nice. I love the look some of your car: the rim closer to the frame. thank you
09-08-2009, 05:55 PM | #2 |
Rep 3,618
Are you sure the fronts are 225/45/18? That's about an inch too tall, and wouldn't correspond with the rears at 255/35/18. So provided it was a typo and the fronts are 225/40/18, then off-hand the sizing looks fine. However without knowing the offsets on the rims it's impossible to say for sure.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
09-08-2009, 08:41 PM | #3 |
Rep 51
Thank you for your respond? how i can find out the offset number? I just double check the number and you are right. The correct number is: F 18x8 225/40/18 R 18x9 255/35/18
09-08-2009, 10:48 PM | #4 | |
Rep 3,618
Edit: If they're oem, take a look here and see if you can narrow it down: http://www.bmwwheels.com/bmwwheels.asp In general though E46 wheels will fit, but may need spacers.
09-08-2009, 10:57 PM | #5 |
Rep 753
If they are off a 2005 then they came from an E46. If they are OEM wheels then they will look tucked in as the E46 ran a 47mm offset in an 8" wide wheel. Your pre lci E90 can run a much more aggressive offset than that. You could possibly make the rims work with spacers.
09-09-2009, 12:39 AM | #6 | |
Rep 51
09-09-2009, 12:56 AM | #7 | |
Rep 3,618
From what I've found, the M Double Spoke 135 in 18x8 are ET47 while the 18x8.5 are ET51. If truly the case you'd need some pretty hefty spacers... thus also adding to the cost.
09-09-2009, 10:54 AM | #8 | |
Rep 51
F: 26mm LESS clearance on the strut side, and the outside edge of the wheel will extend to THE SAME point as the stock wheel R: 36mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 2mm. What they mean? Again thank you. Last edited by BMfan; 09-09-2009 at 11:15 AM.. |
09-09-2009, 12:54 PM | #9 |
Rep 753
Just buy wheels that are made to fit your car. Otherwise you'll need about a 12mm spacer on the front and a 20mm spacer on the rear to get the wheels almost flush with the fenders.
09-09-2009, 01:34 PM | #10 | ||
Rep 3,618
