DIY- Radar detector Hardwire
09-15-2006, 03:47 PM | #1 |
302
Rep 1,928
Drives: had e90, 330i mystic blue
ok here is the DIY that I said that I was going to do
you need: your radar detector hardwire kit ( I have a Beltronics pro 65 and the cable is $21.99) torx screw driver 3M quick connects ( the same ones that I use in the rear outlet DIY) you can find then in any hardware store for $3 for a pack of like 20 time to compleate the mod: 15 mins 1) mount your radar on the windshield try to mount it as low as posible and posision the cable near the windshield ( see picture) 2) fold a brochure or a paper, and push the cable inside the windshield ( see picture 3) went you get to the passenger door pillar push the cable in with a screwdriver or with your hand ( see picture ) 4) went you get to the door push your cable under the side of the door ( see picture do that up to you get under the glove comparment ( se picture ) 5) remove the 2 torx screws ( see picture) 6) push cable in and put screws back ( see picture) 7) remove the center console trim , start from the top and pull up the trim be carefull ( see picture or check ut the DIY on how to install the sunglass holder they show you how to remove the trim ) 8) after removing the trim under the ashtray find the 2 big cables that connect to the ashtray outlet, brown is negative black red is positive ( see picture) 9) use the quick connects to attach the radar hardwire cable to the outlet ( see picture ) 10) test to see if your radar turn on ( it should work) 11) put the trim back, if you have a smart hadrwire cable put the control on the side of the trim ( see picture) 12) enjoy
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
09-15-2006, 03:48 PM | #2 |
302
Rep 1,928
more pics
09-15-2006, 03:52 PM | #3 |
92
Rep 1,730
Are you joking? Look up hardwire V1.
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey) 11 F10 535i AW/CB Mods Gone |
09-15-2006, 03:53 PM | #4 |
Rep 519
Nice work and good pics/description. Isn't it better to have your detector higher up on the windshield for better detection?
'14 535i (ED)
Retired: '08 M5, '08 550i (ED), '06 330i |
09-15-2006, 03:54 PM | #5 |
302
Rep 1,928
V1 hardwire is for high mount, most radar detectors should be mount as low as posible for better results that's why I did another DIY
09-15-2006, 03:56 PM | #6 | |
92
Rep 1,730
09-15-2006, 03:56 PM | #7 | ||
302
Rep 1,928
NOPE YOU ARE !! here http://www.radarbusters.com/support/...detector/2.asp This is the first thing people usually screw up and it’s not really their fault. First off, the cop who is pointing the radar at you isn’t aiming it at your windshield, he’s focused in on your license plate or headlights. If you mount your radar detector up as high or in the middle of the windshield then you are not going to pick up some of the signal that the radar gun is throwing at you. Secondly, why advertise the fact you have a radar detector? Sure they are legal in almost every state (sorry D.C. and Virginia) but most law enforcement personnel do not look too kindly on people with radar devices that essentially help them break the law. Also, your radar detector might entice thieves. Another thing to consider is that the radar detector could be obstructing your view if it's in your line of sight, which is just dumb and potentially dangerous. So set it low as you can, either on the dashboard or the windshield, but be careful your wipers don’t obstruct it. This positioning will help tremendously, especially if you are being targeted by laser which has a smaller beam and is tougher to pick up.
09-15-2006, 04:06 PM | #8 | |
92
Rep 1,730
I am not here to fight, nice write up, however I would never put it down low. http://www.e90post.com/forums/showth...light=hardwire
09-15-2006, 04:11 PM | #9 | |
Law Enforcer
24972
Rep 22,264
Drives: '22 Chalk Gray Porsche C2S
09-15-2006, 04:14 PM | #10 | |
92
Rep 1,730
09-15-2006, 04:15 PM | #11 | |
Rep 2,419
It's a great time to be alive
09-15-2006, 04:18 PM | #12 |
302
Rep 1,928
whatever I just did the DIY to help those who don't know how to do it, no to fight were to mount it, most manufactures say mount it low for better laser detection, and radabusters did the test, but is your car do whatever you want you can put it under the seat if you like
09-15-2006, 04:21 PM | #13 | |
92
Rep 1,730
I was just saying how laser and radar are different and that is why cops like laser. Whatever the last time I got jacked in the car was on the GSP and I was going 115mph. He never used either paced me. lol no ticket either.
09-15-2006, 04:22 PM | #14 | |
92
Rep 1,730
09-15-2006, 04:26 PM | #15 | |
Rep 219
09-15-2006, 04:26 PM | #16 |
302
Rep 1,928
I know thanks I just saying I like it better, went is mount low, if your mount yours high is fine, as long as it make you happy who cares right?
09-15-2006, 04:28 PM | #17 | |
92
Rep 1,730
09-15-2006, 04:32 PM | #18 | |
302
Rep 1,928
Speed Measurement Lab Tests The BEL RX65 was given high marks at the 2005 SML 2006 Radar Detector shoot out, and was the winner of the Long Range Tests. Guys of Lidar Tests At the January 2006 Radar Detector Testing of the Guys of Lidar, the RX65 was the leader in the Ka band 33.8 GHz test.
09-18-2006, 11:06 PM | #19 |
Rep 37
Drives: E90 ZSP that Past on the Right
I just finished the hardwire. For some reason i found this easier then going through the moon roof controls. I just couldn't pop that piece of trim out.
09-18-2006, 11:40 PM | #20 |
302
Rep 1,928
if u cold not remove the trim how did u finish the the hardwire??
09-18-2006, 11:42 PM | #21 | |
Rep 963
Also some of your other arguements for mounting low are pretty lame. If anything, mounting low lets the cop see it more easily, especially when they are talking to you from outside the car. Also the closer to the headliner, the harder it is to notice, so it is less likely to be stolen. Mounting low is like putting it in a store window for sale. Mounting low for laser is also a pretty dumb idea, if the officer targeted your car, its already too late! The only way for a laser warning to go off(and still make a difference) is for the detector to catch fragments from other vehicles, so its a total crapshoot. |
09-19-2006, 12:50 AM | #22 |
302
Rep 1,928
who cares if you have arrows, Got voice or KU band? if my radar beeps, well TALKS that means that there is a cop, that is all that I need to know, I did not did this DIY to fight about with one is the best radar or were it should be mount, I don't care were you mount your detector, you can put it under the sit if you want I don't care, I like my radar were it is and there is no way that I'm going to change it, END of discussion.
