10-14-2009, 07:11 AM | #1 |
Rep 168
Drives: 2009 BMW M3 Coupe, 6-Speed
6000km and breaks squeek
So I got about 6k km on my car and when I break and am about to stop my breaks squeek. Is that normal or are my break already gone bad and need to be replaced. Come on. only after 6k?
---Street-Racing is not a crime---
10-14-2009, 08:35 AM | #2 |
Rep 117
i live in france, on a mountain, beautiful twisites and roads, but all of my cars have had this horrible sound, its a matter of the dust, dirt and whatnot getting on the pads/disc or a combination(dont quote me as expert though). i think youll find that if its the case ur car is fine and happens to alot of people
10-14-2009, 10:45 AM | #5 |
Rep 1,033
10-14-2009, 11:26 AM | #6 |
294
Rep 1,709
Use a pressure washer to clean your wheels/rotors/calipers. I think it may be because of brake dust.
10-14-2009, 02:04 PM | #7 |
NASA SpecE30 Racer
82
Rep 1,307
You probably have something on the rotor or the pad causing the squeak. Perform a pad bedding process and the noise should go away.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
10-14-2009, 02:15 PM | #8 | |
Rep 1,172
I think one can "reasonably" expect pads to last close to 30,000km. 10,000km is too low (by ">10,000km" I guess you don't mean anything above 10,000km, eg 100,000km!). To the OP: IT IS NORMAL, IT IS IN THE MANUAL! |
10-14-2009, 03:50 PM | #9 | |
33
Rep 379
standard pads: 20'000km when used off track performance pads: <=10'000km when used on track; to be precise: this April I bought new performance pads, in September after about 8'000km including 90 laps on the nurburg ring I had to replace the front pads. |
10-14-2009, 08:26 PM | #10 | |
20
Rep 395
It only squeeks when you're just about to stop, while applying the break lightly. I can also reproduce the squeek by breaking lightly while turning either to the right or left slowly. |
10-14-2009, 08:31 PM | #11 |
20
Rep 395
>10,000km is a piece of cake. I already have 13,000km and my iDrive shows front 47,000km and rear 50,000km until the breaks need to be changed. I never tracked and always braked gently.
10-14-2009, 10:44 PM | #12 | |
8300
19
Rep 573
Your front/rear pads new measure 20.3mm/17.3mm in compound thickness. Unless they are at less then 3-5mm they should not need changing for normal street use. iDrive is not accurate at all from what I can tell by looking at the pads. As far as break life is concerned, you can easily expect 30000 miles when driven normally on the street. If driven like an M3 should you would expect shorter life. For example: 280min @ Laguna Seca, 160min @ infineon (half on wet) some 200mi of spirited santa cruz mountains, rest normal driving = 7500mi fronts and 9700mi rears. |
