DIY: Caliper Painting
08-10-2005, 04:20 PM | #1 |
Rep 239
Here's a rough guide to painting your calipers.
Of course you can buy special caliper paint, but over 5 cars I've used Japlac High Gloss Laquer, Colour - Jet Black (of course) and never had any problems with heat. Another good paint would be a gloss enamel, but I have the Japlac, so... For those of you thinking to paint them Silver, I would think again! I've never found a silver paint that has the same smooth enamel type finish, they all have a graininess to the finish which holds brake dust. A very smooth glossy finish keepsl the calipers very clean, since every time you wash the wheels, the calipers get cleaned too. On with the instructions... Unsurprisingly, this is another wheel off job, so jack up the car, remove the wheel and make sure the car is also supported by an axle stand - you don't want it falling off the jack and damaging the brake disk! Depending on how dirty your caliper is, you might want to begin by lightly cleaning the caliper with a wire brush to remove any brake dust or corrosion already there. You don't need to bother priming the surface - usually a single coat of paint is enough to last a couple of years. I find it easiest to apply the paint using a 1/2" paint brush - it's big enough so that it doesn't take all day, and small enough that it's easy to control exactly where the paint goes. Using a paint with a good glossy finish will ensure that you don't see any brush lines as the paint will set to a smooth finish. When painting the caliper, there isn't really much to go wrong. Make sure you keep the paint away from the actual brake pads, and watch for the places where the pads sit, you don't want to restrict their movement as they wear down. Don't be paranoid - just be careful!! It's also ok, to paint the little shield on the front one, and the springy tensioner thing. Make sure and get a nice even finish, and use the opportunity you have with the wheel off to give the inside of the alloy a good clean! You can remount the wheel while the paint is drying, just be sure to leave the car sitting for a few hours while the paint hardens. (Hard I know! ) Once you've done all four wheels you can stand back and admire your work! Sorry - I forgot to take a picture of the front caliper painted, but I'm sure you'll all get the picture... Last edited by nexus66; 08-11-2005 at 03:55 PM.. |
08-11-2005, 09:44 AM | #3 |
17883
Rep 9,376
You didn't pull the line out of the caliper before painting, so no need for bleeding the brakes, right?
The wheel well seems pretty smooth, did you use something else to hang them from while painting? |
08-11-2005, 09:51 AM | #4 | |
Rep 239
Probably if you were under the car you'd see where the paint stops - but how often does that happen! Unless of course you're in the habit of running over people - but I suspect they'd have more to worry about than unpainted bits of your caliper!
Drives: BMW F80 M3 - Sahkir Orange
08-11-2005, 03:24 PM | #7 | ||
Rep 239
08-11-2005, 03:56 PM | #9 | |
Rep 239
08-15-2005, 08:41 PM | #10 |
1427
Rep 16,628
it be black after a couple of years, why paint it black? paint it a color that would stand out. nicely done with the brush i thougt it was can too.
08-16-2005, 11:10 AM | #11 |
Rep 239
Yeah but at least it'll be a shiny black
I don't think bright red calipers would suit the car. Any other colour suggestions? I couldn't think of anything else apart from silver - and I mentioned why I don't like silver!
08-16-2005, 11:47 AM | #12 |
17883
Rep 9,376
Depends on what look you are going for with the paint. For cover-up and to match exisitng, black is the right choice. Want people to think you did some mods, gotta get something flashy. Is there a brushable clear coat?
08-19-2005, 04:02 PM | #13 | |
Rep 239
Don't think you need a clear coat UncleWede... A nice gloss finish is best. I tried a clear laquer on top of silver calipers once, but even then the result wasn't that great! (Again it was with a brush though - spraying might yield a better result!)
08-28-2005, 04:21 PM | #14 |
JOSH SHOKRI.
522
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
hey can you please post a picture from your car like from far? so we can see how it looks.
i have a jet black one too i want to see if theres a difference really. thanks. |
08-28-2005, 04:28 PM | #15 |
Rep 239
I tried that once I'd finished tightie! Unfortunately my camera didn't really pick up the calipers because they're shaded within the wheel. Unfortunately, it's really something you can only see in person. Unless of course you pick a brighter colour like red or something...
08-28-2005, 09:39 PM | #16 |
Custom User Title
17
Rep 215
Has anyone painted their wheel hubs?
When I got my '95 M3 the dealer painted the hubs to match the rest of the car (Avus Blue) and it looked really trick. Likewise best to do when the car is new. Thanks for the great write up! .
tima
get off the phone and drive |
10-06-2005, 05:35 AM | #18 |
Rep 239
'Fraid I don't know - haven't heard of that paint!! But the stuff I use is nothing special so go for it! Worst case is you have to paint them again in a few months...
11-22-2005, 11:01 PM | #19 |
Rep 12
Calipers
Those calipers look wonderful. I am going to take on this project this weekend. I will let you know how it turns out. Thanks for the great instructions, I am very excited.
2006 330i Titanium Silver * Sport * Cold Weather * 6 speed
11-22-2005, 11:48 PM | #20 |
Rep 2,419
I saw lots of Porsche boxters and 911 with red calipers, no matter what color. I saw silver, black, white and blue with red calipers and they all looked awesome. I also saw them in Nissan 350Z. Nice.
11-23-2005, 03:03 AM | #21 |
Rep 239
Yeah - but the Porsche ones also have "Porsche" written in white on them! Unless you have Porsche's carbon ceramic brakes fitted when the calipers are yellow! I don't think Red goes with a BMW but hey - that's just me!
11-23-2005, 12:00 PM | #22 | |
//Mdicted
346
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
