Any idea which JB3 I'm running?
11-08-2009, 12:18 PM | #1 |
Rep 476
So after uninstalling for some work at the dealership, I became curious and opened the JB3. I ordered it late May and it is in the Gen3 housing. However, the chip has 1.2B written on it. So, right off the bat I'm assuming I don't have 1.3 which I thought it came with. Also, does anyone have the map chart for 1.2B? thanks in advance.
11-08-2009, 12:46 PM | #2 |
Rep 7,377
You should order a new chip from burgertuning.com which comes now with the official 1.4 map. You are running a quite old map. Check out n54tech forum for info on jb3.
11-08-2009, 04:57 PM | #4 |
63
Rep 1,884
You dont have 8.4 or 8.5 for sure but you can get those no problem. If it is a Gen 3 board it should have serial ports at both ends of the box. You may still have 1.3 but if you do not have a chip burner just order a new chip and swap it in.
My Youtube Channel
11-08-2009, 05:24 PM | #5 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
11-08-2009, 05:33 PM | #6 |
Rep 476
Yeah, I just saw and replied. Thanks everyone. And here I thought my car was doing big things with the software I was running. Can't wait to try 1.4.
