ZPOST
  TireRack
      11-12-2009, 03:33 PM   #1
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Camber
Just a quick question.
Is it better to have the rears whith less neg camber than the fronts, even if the fronts have low neg camber.
ie my car was just aligned and they could only get -1.13 out of the fronts (pins pulled). The rear they maxed to -3 which is way too much i think for the street.
Im going to go to a different shop, should i have them drop the rear neg camber to be the same as the fronts? Or should i just change the rear to somehting like -2?
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      11-12-2009, 05:51 PM   #2
apexstrafer
14
Drives: Z4 M Coupe
-3 is way too much camber in the rear if the fronts are only -1.13. Rear camber on these cars should never be more than the front, in fact they turn better with slightly less camber in the rear than the front.
Also, you should be able to get more than -1.13 up front with the pins pulled. I have -1.65 up front with my pins pulled (stock otherwise).
      11-12-2009, 06:23 PM   #3
The__J__Factor
Australia
88
Drives: ///M Coupe
^ Thanks for that mate. Yeh i'm going to a different shop, ill have the rear turned to match the fronts.
135i N54 manual
      11-16-2009, 10:48 AM   #4
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
Each car is a little different. I was barely able to get -1 in the front when I pulled the pins. I ended up adding washers to the strut to get to about -1.6
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      11-16-2009, 03:24 PM   #5
The__J__Factor
Australia
88
Drives: ///M Coupe
I went to a dedicated suspension shop and they managed to get -1.5 for the fronts and they lowered the rear camber down as well. So now everything is much better.
So lesson learnt, dont go to non-suspension specialists for alignments.
135i N54 manual
      11-21-2009, 07:46 AM   #6
Kasteel
Drives: BMW Z4M MY07
What you can also try is swap left to right, it's common use @ CSL and makes it possible to go to 2,4 negative (pins out).
My setups:
- with pins in place max 1,00
- without pins max 1,15/1,2
- after swap left/right max 2,4
      03-03-2010, 10:19 AM   #7
blender
Custom User Title
blender's Avatar
Drives: black
There is an inexpensive bolt and washer "shim" kit for the E36M3 that adds neg camber to the front knuckles in ~0.5 degree increments per washer. Turner motorosports has them. Kit allows stock setup to achieve nearly -3 neg camber. Fast and simple, does not require removing struts. More info in other threads here. They fit the Z4M just fine. good luck!
      04-25-2010, 04:52 PM   #8
AUTOXR
Drives: Z4 E85
My setups:
Just want to get this straight. You are talking swapping
the left and right struts?
zpost
