Help!!! bought spacers and lug nuts too long!!!
08-11-2005, 06:28 PM | #1 |
19
Rep 368
I just put them on my car and the car won't move! I called everywhere looking for shorter lug nuts and no one has them! what should I do?
| 2006 325i | Jet Black | Black ette | 6spd manual| Nav | Xenon | Burl | Chrome Tips | 545 sport wheels | Blacklines|
|DOB 6/2/05|Delivered 7/14/05 | |
08-11-2005, 07:00 PM | #2 | |
Administrator
6731
Rep 4,201
we can solve this for you, also what wheels are you using and what size spacers did you get ? |
08-11-2005, 07:24 PM | #3 |
Powered By 36DD
337
Rep 7,369
You need LONGER lug nuts with spacers...not shorter ones.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
08-11-2005, 07:34 PM | #4 |
19
Rep 368
ok... The lug nuts that came with my spacers are way too long... the are about 3.5 inches long. The spacers are only 20mm. I have 545 replica wheels 37 offset. Hope this helps.
08-11-2005, 07:39 PM | #5 | |
Administrator
6731
Rep 4,201
heres what you do, take one of your stock lugs and line it up with the new ones that came with the spacer. Then take a ruler and measure the difference.. that difference should be 20mm If its not 20mm then you can figure out the size you need easily by taking the length of the original lug and adding 20mm to it. Let me know how it goes and we can help you out some more. |
08-11-2005, 07:47 PM | #6 |
Administrator
6731
Rep 4,201
Btw with a wheel with 37 offset a 20mm spacer is a whole lot and you may be pushing it, depending on what tires you have.. the front probably wont take that spacer and on the rear its probably possible, but becareful that the tires arent rubbing on the car
08-11-2005, 07:51 PM | #7 |
19
Rep 368
Ok... stock lugs are 50mm... new lugs are 85mm... so you are saying i need to be at 70mm right? What would make the car not move?
08-11-2005, 07:52 PM | #8 |
19
Rep 368
oh.. I forgot to mention these are only on the rear wheels...
08-11-2005, 07:53 PM | #9 |
19
Rep 368
Wheels are 18 X 8... front and back...
08-11-2005, 07:55 PM | #10 |
Administrator
6731
Rep 4,201
Yea so you definatly need 70mm lugs if your stock ones are 50mm/ because its basicly the distance of your wheel (50mm ?) + the 20mm spacer = 70mm..
as for why your wheel doesnt move, can you explain it better, this is the part that confuses me. Does the lug screw in all the way and tighten the wheel to the hub (to the car)? or is it wobbly ? If so, when the wheel is on the car and the car is on the ground is the tire touching the body of the car at all ? |
08-11-2005, 08:00 PM | #11 |
19
Rep 368
Yes... the lug screwed in all the way and no the tire was not touching the body... I called my wheel place and the guy I spoke to said.. that seeing the lugs are too long... they are hitting the emergency brake... causing the car not to move... does this sound right?
08-11-2005, 08:02 PM | #12 | |
Administrator
6731
Rep 4,201
Let me know if the shorter original lugs let the car move, that would be very very interesting |
08-11-2005, 08:08 PM | #13 |
19
Rep 368
Ok..my brother just took the spacers off and put the orginal lugs back on... the car does move now.... but the thing that concerns me is the fact that a small 15mm too long would cause the car not to move.... Would it hurt to cut the new lugs down to size... I have called tirerack, wheel places, tire places, pep boys, I think just about everything... they all say they do not have anything longer than the stock lugs...
08-11-2005, 08:21 PM | #14 | |
Administrator
6731
Rep 4,201
The best way to test why the wheel is not moving is to leave the spacers ON and put the orignal lugs in, if it moves, then you can definatly say its because the other lugs were too long. As for cutting, sure you can cut down your lugs to match the size they should be. Just be very sure of your measurement before you do anything permanant... so again just to be sure, the length of your new lugs should be the original lugs + 20mm (in your case) But its strange, most places should sell these lugs, try calling up H&R and ask if they have the size you need. (888 827.8881) good luck! |
08-11-2005, 08:28 PM | #15 |
19
Rep 368
Thanks Mark...You have been a great help... I will let you know how everything turns out...
08-11-2005, 10:27 PM | #16 |
19
Rep 368
Just an update.... I ended up cutting the longer lugs down to 70mm and everything worked great! Car looks better.. but could have gone wider. I will post pics later on. Thanks again for all your help Mark!
08-12-2005, 08:25 AM | #18 | |
Administrator
6731
Rep 4,201
perfect, glad it worked out for ya ! |
