Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Max HP/TQ for a Step 6mt
      11-16-2009, 09:23 PM   #1
JPA
Drives: German
What would you all estimate the max power you can generate without toasting an auto 335? Anyone making 400 HP or better having transmission problems?
Thanks,
John
      11-16-2009, 09:44 PM   #2
HPFREAK
63
Drives: C6 ZO6
I am pretty sure they can handle 400 without issue. If you look at Terry from BMS his cars are making over 400hp at the wheels and have been doing so for awhile now and are daily drivers with no issues that I know of.
My Youtube Channel
      11-17-2009, 03:00 AM   #3
Terrance28
Terrance28's Avatar
Drives: Crimson Red E92
We have already passed the 400 mark a long time ago.
Mods list got too long, lets just say more than enough.
      11-17-2009, 03:02 AM   #4
thatsosm
Miracle Whip
thatsosm's Avatar
Drives: 07 e90 AW335i
ASR's upgraded turbo kit/meth put out 540 RWHP
13.16@108.97 2.195 60'
      11-17-2009, 10:00 AM   #5
Sniz
Sniz's Avatar
656
Drives: e92 335 - gone // e36 M3 turbo
the clutch is what needs to be upgraded. Not sure anyone has seen the limits of the actual tranny.
      11-17-2009, 10:04 AM   #6
wakeboarder109
wakeboarder109's Avatar
Drives: in High Country
isn't ASR's 135 a 6MT though?
      11-17-2009, 10:09 AM   #7
Sniz
Sniz's Avatar
656
ah....looks like the OP wanted to confuse us all.
      11-17-2009, 10:11 AM   #8
wakeboarder109
yea, his thread title got me at first too
      11-17-2009, 10:16 AM   #9
john boxter
Drives: 2008 e93
540rwhp? where did you see that? i was under the impression asr upgraded turbos only add 50 or whp
      11-17-2009, 10:18 AM   #10
Proper Motion LLC
Custom Powder Coater
Proper Motion LLC's Avatar
147
Drives: White 335i Sedan
It adds 50WHP or so on pump gas. (91 octane I believe)
      11-17-2009, 10:19 AM   #11
ArmyBimmerDude
ArmyBimmerDude's Avatar
Drives: Lola
Incorrect. Their current vehicle with all bolt-ons, meth, race fuel, and piggyback makes around 550rwhp on a Dynojet. Shiv made a thread and posted some videos if i remember right.
By the way, doesnt a transmission only care about torque?
Thread with graphs:
http://www.e90post.com/forums/showth...&highlight=ASR
2007 E92 Montego Blue 335i
      11-17-2009, 10:26 AM   #12
Proper Motion LLC
147
Transmissions are rated by torque not horsepower. And even the 400WHP N54's are only making about 300ft-lbs @ 6500RPM, and much less even @ 7000RPM.
Altho it still sucks that our 6AT is rated at 333 ft-lbs (ZF-6HP21), and a freaking V6 Hyundai Genesis Coupe is rated at 433 ft-lbs (ZF-6HP26)
      11-17-2009, 10:52 AM   #13
Former_Boosted_IS
Drives: 4 Wheels
It really should't matter where you make the torque though. It is rare you snap a tranny at high rpms, it is normally in the massive torque spikes. I am one of the 400 rwhp N54s you mention and I make over 425 rwtq, so "we" make big torque numbers.
      11-17-2009, 11:04 AM   #14
Proper Motion LLC
147
Then I don't understand why they would give us a transmission that is rated for 333ft-lbs when The BMW Performance Pack 335i is rated at exactly 333ft-lbs, and is obviously underrated.
      11-17-2009, 11:12 AM   #15
Catahecassa
Drives:
413 lb-ft ist the limit for the clutch, 460lb-ft for the manual transmission, 480 lb-ft for the driveshafts.
Clutch will start to slip, transmission will get cracked, driveshafts will getting drilled.
      11-18-2009, 05:15 AM   #16
Former_Boosted_IS
Drives: 4 Wheels
There is a significant difference in what a tranny is rated for and what it will withstand. I suspect there is probably a 20% overhead in the rating, so I don't think the tranny is the biggest concern we have on this car.
      11-18-2009, 06:42 AM   #17
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
Where do these figures come from? I'm curious on whether it's an additional safety feature that is also programmed in the DME, as my Evotech flash although increasing in hp didn't go beyond 560 Nm torque (which is 413 lb-ft); and the new GIAC stage 2 flash seems to go until short of 460 lb-ft (around 623 Nm)...mere coincidence?
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      11-18-2009, 07:25 AM   #18
Former_Boosted_IS
Drives: 4 Wheels
Hold on a second. First let's remember the M5/6 share the same 6MT tranny (ZF Type G). Some facts:
--- The Dinan M5/6 package creates 468 ft/lb of torque and 611 horsepower
--- The M5/6 also weighs about 500 lbs more than the 335i and 900 than the 135i
If you believe for one second that 460 ft/lb of torque is the maximum the 6MT (ZF Type G) will hold on the 135i/335i then you are crazy. The 6MT tranny is the last thing you need to worry about in my opinion.
      11-18-2009, 08:25 AM   #19
ArmyBimmerDude
Drives: Lola
Getrag is known for building robust manual transmissions. I wouldnt worry about that either.
      11-18-2009, 08:49 AM   #20
Mike@N54Tuning.com
Joint Chiefs of Staff
4920
Drives: 2007 335i, 2015 M3
We have seen a few dynos now in the 400-450 range from several tuners.
Mike
      11-18-2009, 09:38 AM   #21
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
does the AT have some kind of torque limiter or it will just handle whats given to it? Think i have read that different gears have different limits...
      11-18-2009, 12:21 PM   #22
JPA
Drives: German
Sorry for the original post's title. But I really am concerned about the Auto-Step. I am not just concerned with brief 1/4 miles or even back to back 1/4 miles. I am wondering about taking a highly modded AT car to the track, and running hard for 20-30mins. Would I need to turn down the power/torque to survive the whole day?
Should I just start over with a 6mt; look into transmission coolers; or what?
John
