ZPOST
Go Back   ZPOST > Marketplace > Sponsors Classifieds
  TireRack
      11-17-2009, 05:26 PM   #1
anthony @ eas
anthony @ eas's Avatar
Drives: R56 Cooper S
▀▄ eas - Rearview Camera & Video Source Module
The Video Source Module (VSM) is a video input for integration for a rearview camera or aftermarket products (e.g. DVD player) with the factory navigation System.
Specifications:
- 1 Video Input
- 1 Camera Input
- Auto Video Switching
- PAL & NTSC Compatible
- Analog & Digital Compatible
- Plug & Play Connection
- Any aftermarket device attached to this interface will work on the move
Kit Contents
- Video Source Module
- Plug and Play harness
- Instructions
- Optional Bumblebee camera with forward/reverse image (end user selectable)
Reverse bumblebee Camera (optional)
Imported overseas from one of the best CCTV Security Surveillance equipment manufacturers in Taiwan, Misumi is well known for applying state-of-the-art CMOS Image Sensor Devices (Camera On A Chip) to the design and manufacturing of security surveillance video cameras.
These kind of cameras incorporate high technology used to minimize the size of the cameras and produce a crisp and clear picture quality. The small and indestructible design allows for mounting virtually anywhere on the vehicle without the need for drilling.
The "bumblebee" camera gets its name from the mounting bracket that can be mounted virtually anywhere from underneath the decklid next to your license plate or underneath the rear spoiler. This is perfect for newer BMWs that do not feature a keyhole, eliminating the need for drilling. The camera features a 150-degree maximum viewing angle and a 0.5 LUX rating for low light viewing, even in dark areas.
Features:
- Significantly decreasing power consumption; operates on 3-12V DC
- Lightweight
- High reliability at low cost
- RCA video input
- Simple installation
- Great for covert use in anyplace imaginable
Specifications:
Water Proof (IP67) Color CCD Camera
Wide Angle View for Reverse Back Up System
Signal System: NTSC/PAL
Pixels: NTSC-512x492, PAL-512x582
Image Sensor: 1/4" COLOR CCD
Lens: 1.9mm/F2.4
Lux Rating: 0.5 Lux
Viewing Angle: 150 Degrees
Dimensions: 19x18mm
Camera to main board box: 22cm
W/Video & Power mixed line (AF-U183)
Models Supported:
10/2002-2006 3 Series (e46, including M3)
9/2002-2003 5 Series (including M5)
10/2002-2007 X5
2004-2009 X3
2003-2009 Z4/Z4M
eas - Video Source Module (VSM) for BMW
http://www.europeanautosource.com/pr...oducts_id=2422
      11-18-2009, 09:43 AM   #2
jonanator
Drives: '08 E93 335i, '06 Z4MC
OMG. I want! How hard is the install of the VSM module and camera?
      11-18-2009, 11:11 AM   #3
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Gaining access to the back of the MKIV computer's connector was the most difficult, otherwise - it's all downhill from there.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      11-25-2009, 11:12 PM   #4
fitchesbass
Drives: BMW
I live in DC where it would be nice to see out the rear from the display more than when just reversing. How hard is it to make the camera switch happen manually as well?
Very cool module. Any videos or screens of putting over devices through the display e.g. dvd etc.? Not that I am big on DVDs in a car... but it would be interesting.
BTW is it just me, or can you still see the camera shot behind the regular display mode? Anyway to avoid that? Sorry for all the Q's
911 Carrera project car
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      11-27-2009, 11:40 AM   #5
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
It wouldn't be hard, the signal input just needs to see a camera signal in order to activate. In the video - we used the reverse lamp's signal so the camera would only activate in reverse.
DVD will be crystal clear on the screen as long as your files are higher than 640x480 resolution.
      11-27-2009, 03:25 PM   #6
fitchesbass
Drives: BMW
Thanks for the info.
Do you have greater details on the switching methods from camera input to other component? It looks like just a 'black box' but I didn't know if there was a wiring diagram that you could share etc.
Just trying to understand how I might be able to utilize the box.
Thanks!
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      11-27-2009, 05:20 PM   #7
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Thanks!
It's simple enough to put into words:
1. 1st input is auto-sensing. As soon as a signal is detected (RCA) the device will switch to that input. When the signal disappears, your screen reverts to normal.
2. 2nd input is activated by a "trigger wire" (+12V) from the device, when the power disappears, your screen reverts to normal.
Hope this helps.
      03-20-2011, 06:23 PM   #8
fighting_fish
Drives: 2.5i Z4 2004
Link is broken, says product not found on your site.
      03-21-2011, 11:57 AM   #9
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Video in Motion for e85 models are no longer available, sorry.
      03-30-2011, 06:37 PM   #10
fitchesbass
Drives: BMW
ahhh darn... that's lame.
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
zpost
