12-15-2009, 03:10 PM | #1 |
Supreme Allied Commander
3816
Rep 54,319
Drives: F80 M3
HP Autosport M3 Adjustable Swaybar Endlinks
When you lower the vehicle, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autowerks is happy to introduce adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. The links are adjustable in length up to an additional 1.25" over stock. HP Autowerks end links are adjustable while on the vehicle. These end links will fit the following vehicles: E90 E92 E93 M3 using aftermarket coil overs. ***Not designed to be used with OEM struts*** Order here: http://www.hpashop.com/BMW-1M-M3-HD-...M-Endlinks.htm $155.99 pair Last edited by HP Autosport; 05-13-2016 at 06:13 PM.. |
12-16-2009, 01:53 PM | #3 | |
3816
Rep 54,319
Drives: F80 M3
Range of adjustment is ~1.25" Last edited by HP Autosport; 07-26-2012 at 12:59 PM.. |
07-26-2012, 12:58 PM | #4 |
3816
Rep 54,319
Drives: F80 M3
HD M3 Adjustable endlinks
Most popular lengths for your M3 are in stock!
05-13-2016, 05:56 PM | #11 |
Track Whore
542
Rep 1,640
Where are these on your site? Do these work for front and rear? (I have no idea if they are they same on the E92M)
05-13-2016, 06:14 PM | #12 | |
3816
Rep 54,319
Drives: F80 M3
http://www.hpashop.com/BMW-1M-M3-HD-...M-Endlinks.htm Front is all you need. |
