Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Do i need spacers?!
      10-18-2006, 12:49 AM   #1
325i.Steve
Drives: E90 325i
Do i need spacers?!
Quick question i just bought new rims but stupid me i was excited and didn't check to see if they actually fit, i asked the person who i ordered it from and he said they would...
SIZE :19 X 8.5 FRONT, 19 X 9.5 REAR
OFFSET : et15 mm front, et22 mm rear
RUBBER : 235/35/19 front and 265/30/19 rear
any input would be greatly appreciated i've seen others using the same size rims, but i dont know how offset works exactly and mine are a little different
      10-18-2006, 02:41 AM   #2
Ray
Member
Ray's Avatar
306
Drives: three series
You may have some rubbing issues with those offsets (definitley with the front) and spacers will only make it worse. I recommend you conduct a search in this forum for the offsets others are using on their wheels with similiar widths.
      10-18-2006, 02:47 AM   #3
325i.Steve
Drives: E90 325i
edit: do you mean rubber as against the fenders?
edit2:http://cgi.ebay.com/ebaymotors/ws/eB...6567946&rd=1,1
hmmmm i'm certain that the guy said they would fit on my e90 and i wrote them emails specifically saying e90, and the guy on the phone said they would fit... lets hope they're not screwing me over!
i noticed everyone else on the forums had +35mm offset
      10-18-2006, 03:01 AM   #4
Pretender
Pretender's Avatar
150
Drives: 06 330i, 07 328i, 16 X1, >17M2
06 330i  [0.00]
Dude, you got the wrong offset. Your wheels will stick out a lot. The rear may work, but still rub the fender over the bump...the font is out of question.
It's a great time to be alive
      10-18-2006, 03:04 AM   #5
Ray
Member
Ray's Avatar
306
with that offset? does it mean that it's a deeper dish then the +35mm offset etc? do you mean rubber as against the fenders? or against the control arm?
Eventhough lower offset give you a bigger lip, they will also stick out/come closer to the fenders. The 35mm will have a smaller lip, but at least you'll be able to drive your car.
Pass on the wheels if you can. They are intended to fit larger BMWs, i.e. 5Series, 7 Series, etc.
      10-18-2006, 12:18 PM   #6
325i.Steve
Drives: E90 325i
nevermind i just confirmed...
FRONT : +38mm
REAR : +25mm
edit: and i know i'm pretty sure the 25mm wont rub since most people on this forum have +35 with a 10mm spacer... which would make the offset +25mm...
thanks for the info guys, once i get the rims on i'll take pictures and post them up
      10-18-2006, 12:30 PM   #7
shragon
Moderator
shragon's Avatar
497
Drives: BMW
^ with those new offsets, you should be fine.
      10-19-2006, 03:01 AM   #8
Pretender
Pretender's Avatar
150
06 330i  [0.00]
FRONT : +38mm
REAR : +25mm
265/30 tire won't rub, 275/30 may be.
