Style 164M on E93
01-12-2010, 07:03 PM | #1 |
583
Rep 2,233
Drives: '12 M3
Style 164M on E93
Looking at buying a winter setup: Style 164 rims with a 41mm offset (Front) and 25mm offset (Rear) and 225/30/18 tires. Will the rear offset work on an E93? I believe the width is either 7.5" or 8"
Thanks! |
01-13-2010, 08:53 AM | #2 |
583
Rep 2,233
Drives: '12 M3
Help?
What about a 18x8.5 w/ 255/35/18 tire ET41 for the rear? |
01-13-2010, 11:16 AM | #4 |
583
Rep 2,233
Drives: '12 M3
Sure the 18x8 et25 would NOT work on stock suspension?? It's skinny enough despite the low offset, no?
01-13-2010, 01:21 PM | #5 |
1569
Rep 29,202
18x8 ET25 with 225/40/18 will fit fine on an e93 in the rear.
01-13-2010, 05:23 PM | #6 |
583
Rep 2,233
Drives: '12 M3
Thanks for the confirmation. I did the math between the two setups (1" width difference vs. Style 230, 0.5" on the outside. Factor in the -12mm offset pushing the new wheel out vs. Style 230s and it should sit at nearly the same spot with respect to the fender) and it seems like an almost identical swap, just wanted to check with you guys first.
Cheers! |
08-09-2010, 07:47 PM | #7 |
105
Rep 280
Hey guys,
From what I'm told these wheels do fit on E93. Does this mean that they will fit on the E92 335i as well? Are wheel fitment the same between the two cars? Thanks alot! |
08-10-2010, 12:56 PM | #8 |
1569
Rep 29,202
They'll fit both, fitment is the same.
