Advice: Agressive setup on E90
01-13-2010, 06:51 PM | #1 |
Rep 418
Hi guys,
I will be purchasing some rims this week and just wanted to double check even though I have done some research. Here are the specs: 19x8.5 Front +32 19x10 Rear +23 I will get Falken FK452 tires in 235/35/19 and 265/30/19. I will also get coilovers to set at the perfect height and roll my fenders. What I want to know is will I rub with a moderate to agressive drop? Will I need to pull the fenders as well? (how is that done?) With a reasonable drop I guess there would be no rubbing at all? Thanks! |
01-13-2010, 06:53 PM | #2 |
Wang D.D.S.
185
Rep 7,057
You will need to fender roll the rear really good for a moderate/aggressive drop, the stance will look awesome. As for the front, I would suggest a little bit of fender rollings, nothing crazy.
01-13-2010, 10:04 PM | #7 |
Rep 418
01-14-2010, 10:26 AM | #8 |
18
Rep 387
I am doing the same setup but will run a stretch 255/30 rear Toyo T1R. Good luck. It should look amazing!
~Chad
Eurowerkz - Midwest Director |
01-14-2010, 11:29 AM | #9 |
Rep 418
01-14-2010, 11:31 AM | #10 |
Rep 1,323
Rear will probably need a bit of a roll. Run a 255 on the back and you may not need to roll at all depending on your camber and ride height
The front will fit no problem. For this reason I would suggest going with a more aggressive offset (or spacers) so that you do need to roll. Aggressive rear, with non-aggressive front will look odd in my opinion. You should go aggressive all around. |
01-15-2010, 12:20 AM | #11 | |
Rep 418
I agree about the front, I will see how it looks and maybe I'll adjust with spacers! |
01-15-2010, 09:55 AM | #12 |
Rep 2,433
yup! i'm using the tein ssp coilover.front rub a little when have really deep drop since i have et30 8.5" and ride height is very low b4.but after raised around half inch now fine.rear do rub little the in liner not on quarter panel when have people at the back.
