Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Besides turbo, what makes e92 engine different from e90?
      10-23-2006, 09:47 AM   #1
d3l0n
I love the ///M3, but I want 550hp ///M5
d3l0n's Avatar
Drives: BMW330iE90
Question Besides turbo, what makes e92 engine different from e90?
I know its got the bi-turbo and split-dual exhaust... but what else makes the two different from each other. WHat does the e92 have that e90 doesnt? and how can I.. a 330i, get the near close performance as that e92??
e90 e92
255hp vs 300hp
220ft/lb torque 300ft/lb torque
what else???
i think if i got atleast 270lb/ft of torque ill be good..
      10-23-2006, 10:09 AM   #2
new2the3
new2the3's Avatar
Drives: 2020 X3M Competition
Direct Injection
      10-23-2006, 10:26 AM   #3
hhhau89
Drives: 2007 335i coupe
twin turbo, the placement of the fuel injectors, just a totally different engine overall! i believe next year the sedans will be housing the new 335 engines. your only bet to getting more power would be either ecu upgrade or forced induction. the coupe itself can not be compared to the sedan simply because they are not the same, there was an article in a mag that said not one body panel is similar to the coupe so its not just the engine, its everything from suspension to materials
      10-23-2006, 11:06 AM   #4
Bimmerista
Bimmerista's Avatar
82
Drives: superstock
The engine block is aluminium rather than magnesium casing, due to the increased strength requirement of the high compression (turbo).
Not a new engine per se, since it uses the same basic components; it is a derivative of the N52 engine, adapted for turbo and DI.
      10-23-2006, 11:38 AM   #5
///Matt
United States Marine
///Matt's Avatar
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
actually... it's a new engine.
Different block design and material, no valvetronic, direct injection with piezo-electric fuel injectors running almost 3000 psi... it's the N54. a new, different engine than the N52. if it was just modified, it would have a different designation, like when vanos was first added to the M52, it became the M52TU. We don't use TU anymore, but it would be something like N52V2HO. but it's not. It's N54.
Matt
      10-23-2006, 11:56 AM   #6
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
148
Drives: circles around you
335 sedans are out on the street already
      10-23-2006, 12:46 PM   #7
Zagor
Sweden
11
Drives: 330i Touring
Gah, please stop this! E92 is the coupe. It's made with many different engines. E90 is the sedan. It comes with an even larger selection of engines, including the twin-turbo 335i.
PLEASE everyone, stop referring to the 335i engine as "E92". It's just WRONG!
[Steps off soap box]
(And yes, I know 335i isn't the real engine name. But it sure beats calling it E92!)
      10-23-2006, 01:12 PM   #8
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
The 335i engine are the same in both the e90 and e92.
But here in Europe the 330i engine is not the same, in e90 and e91 it has 258hp, but in the e92 it has 272hp.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      10-23-2006, 01:24 PM   #9
Ascension
Ascension's Avatar
Drives: 2006 330i & 2010 535i
2010 BMW 535i  [0.00]
2006 330i  [0.00]
I'm confused
2006 330i Jet Black w/ Beige Leather/Sport/Prem/Step/Shades/Xenon/Logic 7
      10-23-2006, 02:44 PM   #10
Kit523
Kit523's Avatar
Hong Kong
375
Drives: F80 M3/FK8/C63S
Originally Posted by Ascension
I'm confused
+1 lol
      10-23-2006, 02:53 PM   #11
Zagor
Sweden
11
I'm confused
Maybe you're joking, but in case you're not:
Here are some of the engine options available for each model:
E90: 316i, 318i, 318d, 320i, 320si, 320d, 323i, 325i, 330i, 330d, 335i, 335d
E91: 320i, 320d, 323i, 325i, 330i, 330d, 335i, 335d
E92: 325i, 330i, 330d, 335i, 335d
...and this is not even a complete list.
Now do you understand why it's a bad idea to talk about "the E92 engine"?
      10-23-2006, 03:12 PM   #12
remmib
remmib's Avatar
Norway
1568
OK, here's the different e90, e91 and e92 options in Norway and in most of Europe, beside the 316i and 320d LE (150hp insteed of 163hp, less tax with 150hp)
      11-07-2006, 04:18 PM   #13
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
Matt
The 'new' valvetronic 330i engine has a 2996cc displacement as the 335i biturbo engine has a 2979cc displacement. The same as the 'old' E46 330i (M54)engine:
http://www.caranddriver.com/reviews/3223/bmw-330i.html
"The most obvious difference between the base 330i and 328i is the additional $590 that buys you six 496.5cc cylinders instead of six 465.5cc cylinders. The blip in displacement is courtesy of a stroke increase of 5.6 millimeters to 89.6mm."
84mm x 89.6mm is the 335i bore x stroke per cylinder....
Can someone inform me if that is the same 'old' E46 3 litre engine, but now with direct injection and 2 turbos etc? I recall reading it's the 'same' in its base specs. ????
      11-07-2006, 08:54 PM   #14
KL2DC
Moderator
KL2DC's Avatar
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
The N54B30 and the old M54B30 share the same (all aluminum with cast iron cylinder liners) engine block.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      11-07-2006, 08:56 PM   #15
KL2DC
Moderator
KL2DC's Avatar
As others have chimed in....a better way of putting the question is N52B30 vs N54B30 engines, what are the differences?
      11-07-2006, 10:49 PM   #16
RiXst3r
RiXst3r's Avatar
274
Drives: M235i
You cant do this with a 328i
      11-08-2006, 03:00 AM   #17
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
I thought so. Thanx.
      11-12-2006, 04:39 PM   #18
GregL
GregL's Avatar
98
Drives: 2016 CLA45 AMG
No sound?
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone
2010 Mercedes-Benz C350 4Matic - Gone
2006 BMW 330xi - Gone
2001 Infiniti QX4 - Gone
      11-18-2006, 05:00 AM   #19
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
There's an E90 316i???
I don't see it on bmw.com
      11-18-2006, 09:25 AM   #20
remmib
remmib's Avatar
Norway
1568
Yes
We got it here in Norway, and I think in Greece and Portugal
Its a 1.6 liter with 115 HP.
