Alignment off after tires
01-22-2010, 11:03 PM | #1 |
Rep 47
So I decide to switch out my Bridgestone Run Flats to Continentals Extreme Contact DWS (great tires btw). However, I noticed that my alignment is off now (pulling to the right at 40mph+) after the new tires were installed. Prior to that, alignment was fine with the run flats (no visible uneven wear either).
Is this normal? Is it recommended to do an alignment after installing new tires? Whats a good place to perform this task and how much does it run? Thanks Guys! |
01-22-2010, 11:56 PM | #2 |
The Main Act
22
Rep 126
I had a similar problem when I switched my 0 day old runflats for winters here.
You can take it to a shop that has a Road Force balancer and ask them to lateral balance it which helps to eliminate the pull. It probably won't be 100% gone (mine isn't) but it is better than have a strong pull at higher speed. |
01-25-2010, 08:18 AM | #4 |
Moderator
369
Rep 4,745
Changing tires doesn't affect the alignment, so something else must be going on.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
01-25-2010, 09:26 AM | #5 |
Rep 47
got my 4 wheel alingment performed. everything checks out. the technician noted "radial pull".
Going to call the tire center for replacement of the "radial pull" tire since the tires are brand new. |
