m6 on stock sport suspension
01-24-2010, 11:15 PM | #1 |
Rep 149
sup dudes! im about to get some m6's 19x8.5 front and 19x9.5 rear on stock sports suspension but still unsure what tire package i should get. i've reseach on this forum and i see alot of running on 235/35/19 and 265/30/19 but still unsure what size and brand i should get. i want something that'll fill up the gaps but at the sametime wont raise the hight of my ride. what would you guy recommend? thanks for the input!
01-25-2010, 01:00 AM | #2 | |
13
Rep 49
Hi, 235/265 is the regular setup for 19's, a very safe;tried & test. The wheels will look good on the sports suspension but some prefer it a bit lower on eibach or H&R but its down to your personal preference. With regards to tires, there are many different brands out there its basically dictated by your budget. Your offset on the wheels is very important; filling of arches & rubbing possibilities. The E90 is normally a safe et35 front & et33 rear but you go down to et30 for an agressive setup. Post pics when you get them fitted. Cheers |
01-25-2010, 09:21 AM | #3 | |
Rep 149
01-25-2010, 12:02 PM | #4 |
Rep 7,433
The offset of the wheel will play the most important role in how well the wheel will fit. If the offset is around ET35, you'll be fine with no rubbing issues. If it's higher (in the 40's) you may need to run a spacer to get it flush. If it's lower (in the 20's) you may need to roll your fenders a bit to avoid rubbing.
01-25-2010, 01:03 PM | #5 | |
Rep 149
01-27-2010, 12:19 PM | #6 |
475
Rep 13,583
Drives: JB E92 335i
For the M6 type 346 wheel the size and offset that I would recommed for your car is 19x8.5 ET35 in the front and 19x9.5 ET33 in the rear which will give you the perfect stance on your car without any rubbing issues.
01-30-2010, 10:06 AM | #7 |
Rep 149
