BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Another garage door remote intall:)
      01-27-2010, 04:46 PM   #1
WWJDrive
WWJDrive's Avatar
Drives: 325i
I know there is other write-ups on this but I though I would share my experience...
you will need two buttons, a soldering iron, wire, a drill and twisty ties
this is the clicker I have
and these are the buttons i bought from radio shack
First take apart the clicker...these are the pegs you will need to solder to(highlighted in red)...I only used two of the three buttons but if you use the third then you would solder to the pegs highlighted in yellow.
once you solder your wires to the circuit board and solder the buttons secure the battery back in the clicker. I broke the clips on myne so I used zip ties to secure the remote to a piece of wood
mark and drill two holes for the buttons to go through-i took the button tops off to make for a sleeker look...also easier to get through the holes
next drill through the ash tray where you want the buttons to pertrude(i got impatient here and as you can see chipped the ashtray a little, slow it down and be careful
find a good place for the clicker to sit, i found some free space between the idrive nob and my center armrest
glue or tape the buttons securly to the backside of the ash tray or if you bought buttons that have nuts on them to tighten do that.
put everything back together and enjoy you new opener...
      01-27-2010, 05:34 PM   #2
bmrm396
Drives: 2018 F80 M3cs
not a bad idea ...
so do u have to take ur whole center console apart when ur batts die in the remote?
Formerly addicted to e46fanatics
Formerly addicted to e90post
      01-27-2010, 05:41 PM   #3
Rotary Rasp
Rotary Rasp's Avatar
241
Drives: 2009 E92 335i 6MT
whoa, those wires are a little overkill! some 24/22awg wire would have been fine. lol
      01-27-2010, 07:38 PM   #4
WWJDrive
WWJDrive's Avatar
Drives: 325i
when the battery dies i do have to pull it out, when I did this though i went and bought a new battery so it should last a while...
it was the only guage wire I had layin around, i could have made a seperate trip but i was eager to get it in---does the job tho
      01-27-2010, 08:56 PM   #5
lkn
lkn's Avatar
Drives: 335i
I had a similar setup on mine but took it out. The only thing different was my remote control was under the passenger's glove compartment. I think if you tuck it under there then you'll have an easier time to replace batteries instead of removing the entire center console.
      01-27-2010, 09:44 PM   #6
WWJDrive
WWJDrive's Avatar
Drives: 325i
you are definitly right, i may try that next time i need to replace the battery.... i didnt find taking the center console out difficult at all so really its no big deal but i do agree.
