Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Running aftermarket wheels WITHOUT tire pressure sensors...
      10-26-2006, 06:10 AM   #1
fueledbymetal
fueledbymetal's Avatar
129
Drives: 2024 G80 6spd, Cayman GTS 4.0
...has worked OK for me so far. I had bought my new wheel/tire combo before I found out that the '07's have in-wheel sensors. I thought a dummy light would have illuminated at the very least, but I've driven over 50 miles and haven't had any sort of error or caution messages from the car. I was planning on installing a set of sensors, but now I think I'll just save the cash and continue to check my tires myself as I have on every other car I've owned
fwiw, my wheels can be seen here:
http://www.e90post.com/forums/showthread.php?t=34478
Instagram: te37sl_m3
      10-26-2006, 04:16 PM   #2
3thirty5
3thirty5's Avatar
95
Drives: 2014 BMW M5
2014 BMW M5  [0.00]
good to know, i was actually wondering about that too... now i know i could save some money.
      10-26-2006, 04:58 PM   #3
arbitrage
arbitrage's Avatar
14
Drives: 07 335i coupe
e90 doesn't have in wheel tire sensors, only e92! Even the 07 e90s have all shipped so far with the regular ABS system so thats why you don't have a problem. My e92 doesn't have sensors either but I'm in Canada, Canada has no in wheel sensors on any model.
Ordered June 3 '06: E92 335i Saph Blk, Jade Grey lthr, poplar grey trim, 6spd, Sports Pkg, CA.
Update Sept 29 '06: Got the car...It rocks!!
Update Sept 08: Moved to Whitehorse and had to buy out of my lease. Miss the car a lot. Will return to BMW family in a couple of years.
      10-27-2006, 06:12 AM   #4
fueledbymetal
129
It would be nice if you're right, but E90Fleet has stated all '07 US e90/91/92 have wheels sensors as does the Tire Rack.
Also, the OP in this thread said his sedan came with sensors and that he swapped them into his new wheels...
http://www.e90post.com/forums/showthread.php?t=33933
FWIW, I'm up to 89 miles without any errors on my "sensorless" wheels
      10-27-2006, 08:05 AM   #5
kuthair
Drives: 07 335i Sedan 6MT
Even tho your wheels dont have the in-wheel sensor, the nice thing about these BMW's is it'll still use the ABS sensors to monitor your tire's pressure like the 06's. Atleast, that's what I got from reading the manual.
      10-27-2006, 08:43 AM   #6
arbitrage
arbitrage's Avatar
14
That thread is an e92, not an e90. So far I haven't seen any posts about e90s having sensors in the wheels. But I guess in the end all that matters is that you at least don't have an annoying light!
      10-27-2006, 08:46 AM   #7
kuthair
My E90 manual says I have TPMS and the regular tire sensors.
      10-27-2006, 08:47 AM   #8
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
So far most 335i sedans have come though with ABS based systems despite what BMW was telling us earlier. All 335i coupes (well, not Canadian ones) have come with the sensors from the factory.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      10-27-2006, 08:50 AM   #9
3thirty5
3thirty5's Avatar
95
Drives: 2014 BMW M5
2014 BMW M5  [0.00]
so all Canadian models (E90 & E92) don't have the sensors in the wheels?
      10-27-2006, 08:52 AM   #10
kuthair
Man, I wish I checked the iDrive menu before I dropped my car off...
Can someone with a 335i Sedan check their iDrive for a calibration menu for TPMS.... its in there similar to the calibration for ABS tire sensors. I'm guessing if the calibration menu is there the car will support TPMS whether the tires have the sensors in them or not.
      10-27-2006, 09:53 AM   #11
pdtar98
pdtar98's Avatar
Drives: 03 330xi,07 328xi,
I swapped the wheels out on my 328xi coupe and it did turn the warning light on in the dash. The new wheels didnt have the sensores installed so now I live with a flashing yellow light on all the time. Theres no way to reset the TPS if the wheels arent equiped. I will be buying the sensors and installing them soon!
Guess I should have thought of that before I mounted the tires!
      10-27-2006, 10:45 AM   #12
kuthair
^ is your 328xi a coupe or sedan? thx.
      10-27-2006, 12:06 PM   #13
fueledbymetal
129
Doh! My bad
Yeah, that's all that matters to me at the end of the day - I check my pressure regularly myself, so this is technology I can live without
      10-27-2006, 11:22 PM   #14
pdtar98
pdtar98's Avatar
Mine is a coupe
      10-27-2006, 11:31 PM   #15
Barry626
Drives: Coming: 2012 135i
I have 07 335i Sedan and it does not have separate tire senors just like 06 models.
      10-29-2006, 04:27 AM   #16
E90Fleet
South Africa
1312
Drives: BMW
Only the US E92 has the in wheel pressure sensors so far ( and some 5 Series )
The E90 will get it some time soon, to comply with the US requirement
BMW if you are reading, I need a job, Please.
