20" possibility
10-26-2006, 06:29 PM | #1 |
Modeldater
22
Rep 641
20" possibility
I have come across some 20" Beyern Mess wheels brand new in box for a great price. THe problem is I'm not sure the backs are going to fit. I currently have a 330xi lowered with H&R Sports. The offset on the rear is +25ET. The wheel is 20x10. I'm thinking that it is just too aggressive of an offset to run the 20x10 set up. Any opinions or people with experience?
10-26-2006, 06:50 PM | #3 |
United States Marine
319
Rep 2,748
I think you are right, that that is too aggressive, since you are lowered on H&R. If it was narrower, OR less aggressive offset, you might be ok, but the combination of these two WILL make you rub. =( The positive side says, "maybe rolling the fenders will correct it?"
Matt |
10-26-2006, 06:54 PM | #4 |
44
Rep 1,859
So, the higher the offset the more agressive? What is the perfect offset front and rear for a 330i? Regarding this wheels in particular?
10-26-2006, 07:04 PM | #6 | |
1571
Rep 29,202
10-26-2006, 08:01 PM | #7 |
Rep 1,440
Nic, I believe that 20x10 +25 on an H&R sport drop without rolling the fenders might rub on huge dips since the diameter is bigger and will be close to the fender lip, also, you it will depend on the tire size that you will choose. GL!
10-26-2006, 08:03 PM | #8 | |
Modeldater
22
Rep 641
Ideal offset for 330 is around +28-+30 rear and +35 front. Front may be off someone can correct me. |
10-26-2006, 08:44 PM | #10 |
Rep 1,440
+35 on the fronts with 20x?? if its 8-8.5inch, you'll be fine. considering youll throw a 225/30/20 tires on the front to prevent rubbing on the liner when you hit a dip.
10-26-2006, 09:30 PM | #11 |
319
Rep 2,748
I just put 19x8.5 and 19x9.5 on mine, with 245/35 and 275/35 (I know, not ideal tires, but they were cheaper!)
They are 38 and 40 offsets. I'm on factory sport springs. HOLY CRAP. it looks SOOOO good. I'm in heaven. I'll post some pics in a couple days, but DAMN fine. offset in the FRONT could use just a FEW millimeters, like maybe a 10mm spacer, or basically a 28mm offset. the rears sit REALLY NICE, and look very aggressive, but I suppose you could put up to a 15mm spacer in without rubbing. I think they look AWESOME as is, though. Matt |
10-27-2006, 03:00 AM | #12 | |
11
Rep 141
Drives: 330i Touring
Looking forward to the pics. |
10-27-2006, 04:49 AM | #13 |
Rep 158
most likely your gonna rub with +25 in the rear. unless u go with 265 which will make your tires very look streached on 20x10
2006 325i Jet Black (5-21-06)
