PROcede questions
01-31-2010, 01:52 AM | #1 |
Rep 214
PROcede questions
I know how a JB3 works and what maps they have like Map1 is the low boost and map 5 is high boost etc. My questions about the procede is in regards to how it works. Im a noob at tuning and need something that i'll be able to know how to use. Im looking to get a procede but have some questions and am hoping to find some answers with the knowledge of the bimmerpost community.
1) Is there a description / list of the PROcede maps like BMS has for the JB3? low boost or highboost or meth etc. 2) If you change maps using the DTC button does that render the DTC button useless as I like to still be able to turn it on and off. 3) Also how would you clear codes with a Procede. I know BMS uses the Bavtech cable which is a sinch. Is it similar with the Procede? 4) Around how much is a PROcede V4. I'm hearing if you get the ones with remotes then its more expensive? what do the remotes do? Sorry for all the bad noob questions. I'm just getting started in tuning. THANKS! |
01-31-2010, 04:57 AM | #2 | |
Rep 4,647
and you can adjust each setting to cater your taste through laptop hooks on to the v4 2) i would like to know this too. 3) no tools needed to erase code. few steps to your gas pedal and you're done. you need laptop to hook it up to procede to see the code though... 4) wrong info. price should be same. contact shiv!
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
01-31-2010, 05:07 AM | #3 | |
Rep 677
If you want to change TC you push just once.
59 Corvette, 72 240Z, 73 Espada, ZXR
01-31-2010, 01:30 PM | #4 | |
Rep 214
I have a stock car. Is there a map for that? what are the boost pressures on V4, can these be adjusted with a a laptop?
Is the V4 diagnostically invisible like the JB3? Quote:
01-31-2010, 01:39 PM | #5 |
Rep 4,647
there's valet (stock) map and stage 1, 2, 3, and 4.
i believe stage 1 is 13~14, 2 is 14~15, then 15~16, and 16+ AFAIK and yes it can be adjusted with laptop. and i believe v4 is also diagnostically invisible since it connect directly to CANBUS.
01-31-2010, 01:46 PM | #6 | |
Blah blah blah
Rep 149
The boost pressure is adjustable. I've seen 12psi peak-under-load on a manifold boost gauge running v.4.001 with an otherwise stock car. The boost level is adjustable through the laptop software. I think most people clear codes with the Procede (as described above) and remove it before getting in a diagnostic situation.
Ian 2009 e90 MT
01-31-2010, 01:59 PM | #8 |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
For a stock car, the stage 1 map is the map to use. Although, with stg 4, we are testing the stability of higher stage maps in stock cars.
All rev2 Procedes are diagnostically invisible because they have a built in diagnostic tool that can read and clear codes. With this native function, there is no need to castrate the tunes to achieve the same result. As mentioned earlier, DTC functions like usual. It is not disabled in any way. Mapswitching works by double-clicking on the DTC button as you would on a mouse. A visual on-dash indicator of map selection and traction control status makes sure that you are well informed of settings. Shiv |
01-31-2010, 02:01 PM | #9 | |
Rep 2,875
FWIW, I'm in the NW and granted I have the V3 Rev.I, but I have been running Stg.3 for a while with no problem.......I've got catless DPs, DCI, FMIC, and stock exhaust w/ secondary cats. I also tried running stg.2 but upped my UT value a bit and lowered my ign. correction a bit, and that worked out fine as well. When I'm on Stg. 3 though, I leave all the UT value alone (default). So some might be able to get a way with running stage 3, and some might not. The best way to tell if the map is too aggressive is to datalog your runs and analyze the graphs. That'll tell you what's cooking in the kitchen, if you know what I mean.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
