01-31-2010, 04:33 AM | #1 |
Engineer
215
Rep 2,122
Drives: M235I 2015, 335i 2011
Understeer vs Oversteer
Based on individual opinions what do you guys experience at the most on the Z4 MC with OEM setup??
What did you do to correct or adapt to your way of driving?? What was your goal?Street or Track? % if both. |
01-31-2010, 04:08 PM | #2 |
Imola Lover
26
Rep 749
These cars are known for understeer. More negative camber in the front mostly addresses this.
02-01-2010, 01:34 AM | #3 |
Rep 164
Understeer factory. As noted more front camber and the car is very nuetral. You can do this by simply shimming the two bottom strut bolts to get the needed -2.5 camber.
MR-S Track -2100lbs/300hp
Miata Z4M Coupe (Sold) |
02-20-2010, 01:40 AM | #5 |
Engineer
215
Rep 2,122
I'm going with -2.75 front, toe .10 and -2.45 rear toe .10
02-22-2010, 06:03 PM | #6 |
Rep 164
Why so much rear camber??
06-02-2010, 03:48 PM | #7 |
Engineer
215
Rep 2,122
Tags |
suspension |
