03-08-2010, 12:40 PM | #1 |
Rep 240
TC Kline D/A Coilovers (settings & alignment)
Hello,
Wondering if I can get some input on what settings you guys are running with your coilover setup. I just installed TCK DAs w/ camber plates and I need to get an alignment, what camber & toe settings will suit best for street? during track days I can slide the camber to -2.5. Thanks! |
03-08-2010, 06:48 PM | #2 | |
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
http://www.bimmerfest.com/forums/sho...7&postcount=74 At -2.0 degrees front camber I have 0.06 degrees toe in and 7.7 degrees caster. At maximum -3.5 degrees camber for the track the toe is at 0.1 degrees out. In the rear I'm running -2.0 degrees camber and 0.18 degrees toe in. I have the ride height at 25.25 inches front and 25.75 inches rear measured from the bottom of the side rail to the ground; you want at least 0.5 inches of front rake.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
