Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Winter Tire install costs?
      11-10-2006, 09:19 AM   #1
Chuck_IV
Drives: 2006 325xi
2006 325xi  [0.00]
What do you think is a reasonable cost to have your current tires removed and new snow tires mounted and balanced? Most places are quoting me $30 per wheel($25 for the mounting/balance of the new ones and $5 dismounting the old ones). Just wanna make sure this is reasonable.
      11-10-2006, 11:59 AM   #2
tirana
15
Drives: M2 6MT + F25 35i AT
Hydraulic trolley jack + axle stands: $60
Torque wrench: $40
Freedom to change wheels over whenever you want: priceless
Yes, those are reasonable prices you were quoted. It takes a shop about 20-30 min to do if they lift the whole car.
      11-10-2006, 01:31 PM   #3
in13
Drives: 330i
Are you talking about just removing tires from the wheels and putting new tires on the same wheels? If so, I founds several quotes that were about the same as that. $30/wheel.
      11-13-2006, 09:10 AM   #4
Chuck_IV
Drives: 2006 325xi
2006 325xi  [0.00]
Yea, I need the existsing tires removed from the existing rims, then the snows mounted on the rims, then onto the car. I found a local place, that will do it for $27.50 a wheel. They are listed at Tirerack.com and have great reviews, so we'll see. The car is in, having it done, as I type this.
      11-13-2006, 09:30 AM   #5
Carnage
Carnage's Avatar
Drives: people insane
Torque wrench: $40
Best advice so far.
      11-13-2006, 09:32 AM   #6
Carnage
Carnage's Avatar
Have you considered getting wheels for the winter tires and saving the wear and tear on the current wheels from switching tires twice a year?
      11-13-2006, 10:30 AM   #7
Chuck_IV
Drives: 2006 325xi
2006 325xi  [0.00]
Since I currently have 16" rims, I'm doing it the other way around. I'm putting the snows on the 16's and when spring rolls around, buying a set of 17's with summer tires.
      11-13-2006, 12:18 PM   #8
tirana
15
Good plan. The 16" will make a good winter set and the 17" summers will give you the extra performance. I went from 18" summer to 17" winter and although I miss the summer smoothness (almost hovercraft-like), the winters are behaving very well so far.
