03-15-2010, 07:27 PM | #1 |
BimmerPost Supporting Vendor
8058
Rep 18,786
Drives: BMW
▀▄ eas - mObridge DA1000 MOST Preamp for BMW
The mObridge preamp is designed to seamlessly integrate into the MOST bus system and interface into the audio digital data stream to allow any aftermarket amplifier to be added to your audio system without the need to use "HIGHtoLOW" audio converters. The mObridge preamp interface operates on a digital level and does not introduce unwanted noise levels and harmonic distortions that an analog converter hooked into the existing wiring of the vehicle would give you. The piece connects into the MOST bus vehicle system without having to cut into the speaker wiring of your premium vehicle.
The mObridge preamp gives the user complete control over volume, fade, balance, treble, bass and equalization settings. Utilizing a state of the art powerful 400 MHz Digital Signal Processor, the mObridge preamp is able to take advantage of the digital domain space and provide the user with complete control for the existing vehicles interfaces such as the BMW iDrive. Specifications - Digital SP/DIF TOSLINK output - High performance Digital Signal Processor - Volume, Bass, Treble, Balance, and Equalization control - External Amplifier power control - SD card user settings file - SD card firmware upgradeable - Single unit is configurable across multiple vehicles - Seamless Audison Bit One integration Compatible with the following vehicles 2008+ e8x 1-series 2006+ e90 3-series Coupe, Sedan/Touring & Convertible, including M3 2004-2008 e60 5-series, including Touring & M5 * 2004-2008 e63/e64 6-series, including M6 2004-9/06 e65/e66 7-series 2007-2008 e70 X5 2007-2008 R56 Mini Cooper Coupe 2008-2008 R55 Mini Cooper Clubman 2009-2008 R57 Mini Cooper Cabriolet Notes: Requires activation from BMW or MINI dealer after installation if not originally equipped with LOGIC7 or Enhanced Premium Sound sound system. e60 5-Series M-ASK iDrive (04-06) model compatibility will be arriving in Summer 2010. mObridge - DA1000 Preamp for BMW http://www.europeanautosource.com/pr...oducts_id=3124 For local members, installation/coding is available in-house.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
