Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: DEI 504D shock sensor Harness...Version 2!
      03-22-2010, 02:46 PM   #1
my07_335i
Drives: 2007 E90 SMG 335i
2007 335i  [0.00]
Parts List:
some super glue
pair of needle nose pliers
Roll of 22-26 Gauge stranded wire
2x 8 position housing w/ .1" spacing non-polarized
8x Female Post connectors
8x Male Post connectors
If you buy from Jameco, like I did, you have to buy the pins in sets of 10, so it comes out to be 1.90+1.50 +.80, or about 4.20$ total for the parts.
Time Required:
about 20-30 minutes...less if you have a hand crimper for these things, otherwise a pair of needle nose pliers works fine
Step 1.)
strip off 1/4" or a little less of the ends of 8x 3" pieces of wire. Twist it so it doesn't unravel. insert it into the end of one of the connectors (female or male) and either carefully use the pliers to bring down the edges of the terminal to secure the wire, or use your crimpers. then pinch the wire guide part of the connector. This should secure the wire in the connector fairly well, however I then used the super glue to secure it even better. Once done, push the connector all the way into the end of the housing. (Sorry I don't have any pictures of the steps involved here, was hard to do this and take pictures since the parts are so small)
Repeat 7 more times.
You should have this:
Step 2.)
Do the same as step 1, except with the male pins. You'll have to do this a little differently however for 3 of the pins (the ones that connect to the DEI harness).
You have two choices, you can either strip part of the wire mid way up the cable, or, if you used smaller gauge wire (24+) you can just twist your DEI wires in the end and insert into the connector) I used the mid-line method). I slid some shrink wrap tubing over the wire, and then once I twisted my DEI wires inline, I move the shrink wrap over and shrunk it.
The resulting harness will look like this:
Step 3.)
Install the harness into the alarm unit, and mount the sensor in the alarm tray in the open spot (it fits perfectly):
up-close mounting of the DEI module:
IF you have any questions, please let me know.
'07 SGM + DG 335i sedan|Navi|ZPP|Rear PDC|Euphoria 6k LED interior|Matte Black Grills|OEM Blacklines|MTEC A.E's|CF Roundels|Alufelgen 19" CS7 with 15/12mm spacers
If I buy something from you please leave me feedback
My Portfolio
      03-27-2010, 08:35 AM   #2
aah78
aah78's Avatar
12
Drives: 2008 BMW 335i, 2014 BMW 550i
Arrow shock
Hello, I'm assuming that no changes to / re-programming is required on installing the sensor?
I wonder if this is actually required as my car, without the shock sensor, when parked near a railway track starts beeping whenever a freight train passes by due to the vibration.
      03-31-2010, 05:12 PM   #3
my07_335i
2007 335i  [0.00]
no reprogramming is required. I don't know why yours starts beeping, the factory alarm, at least on E90's doesn't have a shock sensor built in, at least not on most of the cars. This is why it's easy to add the DEI module. I built a harness to prevent having to cut any factory wires or use wire taps.
My Portfolio
      08-19-2011, 07:21 PM   #4
Elliott@DetailAddict
Drives: E90
Great upgrade. Cheers for the parts list!
      11-02-2011, 01:48 PM   #5
jazz5000
36
Drives: F82 M4 + F13 M6
Is there anyone out here willing to make me a harness and ship it out to uk?
Il pay of course.
Having trouble finding the parts out here
      06-30-2012, 06:16 PM   #6
Brent
Drives: 2008 328i E90
Excellent DIY
I just finished my install of the "D" sensor. I may have set it a bit too sensitive, but I wl see how I do with false alarms before I change anything. Thanks for a great DIY and a parts list!
Question: how can I confirm that the ultrasonic sensor is still working? The manual says all the windows including the moon roof must be closed for it to arm properly. How can you test the ultrasonic sensor with everything closed?
Also, it appears that double locking, which supposedly shuts down the ultrasonic and tilt sensors, does not affect this new shock sensor. I did the double lock, confirmed via the clown nose that it was in the other mode, but the shock sensor still set off the alarm when challenged. I was surprised as I though the sensor would do whatever the ultrasonic did. Perhaps the ultrasonic sensor does not power down, but somehow is simply ignored. I am unsure how a sensor in parallel on the same circuit can still set off the alarm but it does!
Update
The ultrasonic alarm does in fact arm even if the moonroof is left partially open. I tested it after a bit to let the ultrasonic get it's base reading. I just stuck my hand and arm in holding my iPhone. It went off. Interestingly it is hard to set off with just your hand, but stick a hard object in your hand and it goes off immediately. I guess the object reflects the sound waves better.
      11-11-2012, 08:18 PM   #7
toicy4ya
toicy4ya's Avatar
47
Drives: 06 BMW 330XI
I just attempted to install it on my E90, the shock sensor light goes on but when i attempt to arm it or trigger it i get no sound from the siren. The following are some pics, anyone know what i might have dont wrong?
2006 330XI BSM, Terra Cotta Leather Interior, ZSP, ZPP, ZWP, ZCV, Comfort Access, Adaptive Xenon, Steptronic, Logic 7, Nav w/ IDrive
      11-26-2012, 12:30 PM   #8
Drives: E90
Make sure your connections are soldered, and actually pushed in and locked into the harness ends.
      01-18-2017, 03:21 PM   #9
vladmury
vladmury's Avatar
Denmark
101
Drives: 325d E90 LCI M-sport
my alarm acivated due to the shock sensor, i could not stop the alarm even after openinng the car with the fob key. any ideas why? it stopped only after renoving the shock sensor
      11-13-2019, 02:28 PM   #10
m/335
Drives: e92 335i white
Anyone know if the compustar DAS would work with the factory alarm?
      11-13-2019, 06:26 PM   #11
Blueeyesredpanda
Blueeyesredpanda's Avatar
401
Drives: E90 / F30
How much was it to install the Computer DAS?
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
      11-15-2019, 10:29 AM   #12
m/335
I haven't installed it yet. Was just wondering if the DAS would work with the factory alarm like the DES.
