BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Auto Transmission Fluid Change
      03-28-2010, 09:32 AM   #1
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Disclaimer: Do this DIY at your own risk. Not responsible if your trans fails or you get injured.
Car: 2006 325i Step Auto 49,300 miles (I have a ZF trans., check posts 73 and 74 to see if you have a ZF or GM Trans.)
Materials:
6 Quarts Castrol Import Multi-vehicle trans fluid ($4.50 - $5 a quart) (See attached spec sheet). UPDATE/NOTE: CASTROL CHANGED ITS FORMULA. IT NO LONGER LISTS BMW. ALWAYS CHECK THE SPEC SHEET.
1 clean bucket ($1 store)
Transfer pump: $5.99 at harbor freight
4 quart drink container ($1 store)
Digital thermorter ($3.12 Walmart) I didn't use it (will explain later)
Tools:
3/8" ratchet
small extension
8mm socket
8mm allen wrench
10 mm allen socket
Any size wrench (I used a 17mm) (will explain later)
4 jack stands
1 Jack
Goggles
Instructions: (Again, at your own risk)
1) Jack up the FRONT of your car 1st and place jack stands at the jacking points on the sides of the car. (Rear wheel drive, therefore must jack up the front of the car first.)
2) Jack up the rear of the car under the differential (Not the cover) and I wouldn't recommend doing it under the cross beam, it looks sturdy, but BMW doesn't mention this spot as a jacking point.
3) Using the 8mm socket remove the transmission under-cover.
4) Using the 8mm allen wrench and "any size wrench" (I used a 17mm wrench) open up the fill hole (see pic). The "any size wrench" will give you leverage. This would be extremely difficult without the extra leverage. You may also want to use goggles because my allen wrench was bending when I applied force (I thought I was going to break it!). Also, there is no space for a socket and a ratchet. Further, place your oil-catch under the fill hole because a lot of oil spilled out of the FILL hole. That shocked me because how am I suppose to fill it up when it was GUSHING out the FILL hole. I figure it may have to do with the temperature of the oil.
5) Using the 10mm allen socket open-up the drain plug (see pic)
6) Place the used oil in the container to see how many quarts came out of your transmission. 4 1/4 quarts came out of mine. I know, I know, what about the torque converter. Something is better than nothing. Plus I plan on doing this every 20,000 miles so the next change or so should get alot of it out. (Castrol recommends 15,000 to 30,000 miles changes). Besides, its lifetime fluid so who cares about the fluid in the torque converter.
7) In order to do this job on my own I filled the dollar-store bucket with 6 quarts of oil. 6 quarts because the transfer pump hose will have problems getting the fluid at the bottom of the bucket; the hose tends to curl.
8) With the drain plug back in the trans, start pumping fluid back in the trans. until oil starts spilling out of the fill plug. See pic. You may want to cut some of the hose length of the transfer pump (those hoses are long). I cut about a foot off each hose.
9) Re-install he fill plug and start the car. Shift through the gears slowly WHILE PRESSING DOWN ON THE BRAKE (ie: P->D wait, D->P wait, P->R wait etc.) You might see a symbol of a car with arrows pointing in both directions. That is just a warning that your car may roll because the parking brake is not engaged
10) After about 8 minutes (you do not have to shift through the gears all this time), with the car still running, I placed my hand on the transmission pan, it was warm therefore it should be between 86 -122 degrees F. I opened up the fill hole and no oil was coming out.
11) Here is where you may want to insert the temperature gauge in the fill hole. I forgot to do this because I was nervous that my engine was running and I know the trans was low on oil. But at least I knew how many quarts came out of it.
12) Fill the trans until oil comes out.
13) Re-install the fill plug, re-install the trans cover, jack the car down, and you are done!
Overall experience: The oil was golden yellow to black and it contained some gray matter (friction disc material). I used about 4 1/2 to 5 quarts of oil. The car feels exactly the same; which is a GOOD thing! I plan on doing this every 20,000 miles (that is why I went with Castrol, cheap and it specifically lists our spec.). Assume everything is fine unless I give an update here. I plan on changing the filter next time around. Good luck.
Appreciate 3
      03-28-2010, 02:03 PM   #2
mike3000fl
138
Drives: 06 330i
thanks for putting this up, i want to do this soon too
your choice of ATF, its not the OEM stuff i assume so is there an issue with mixing it with the fluid left in the TC?
      03-28-2010, 09:03 PM   #3
Chriztofor
Chriztofor's Avatar
^ I have no clue, only time will tell. At least the oil is recommended for use in our vehicles.
      03-30-2010, 05:57 PM   #4
saeng
Drives: e90
after you started the car did you put more oil in? If so did you do it well the car still on?
      03-31-2010, 08:23 AM   #5
Chriztofor
Chriztofor's Avatar
^ yes, see instructions #9 through #12
      06-03-2010, 02:36 AM   #6
E90DTM
BF.c <3
E90DTM's Avatar
Germany
18
Drives: e9o
i used this oil about 3k miles ago too
so far so good!
      06-08-2010, 08:20 PM   #7
JBE9006
Drives: E90 330i/JB/Prem/Sport/STEP
Great DIY.
I got my 330i w/64k and is now hitting 75k mi.
I've heard that for tranny fluid changes you either do them religiously or don't
do them at all. I'll go with the latter since I'm pretty sure it was never done
by the previous owner.
      06-09-2010, 09:00 AM   #8
Chriztofor
Chriztofor's Avatar
Originally Posted by JBE9006 View Post
Great DIY.
Thanks. But supposedly the oil lasts to 100,000 miles, so you might be ok changing it (along with the filter). Especially if you plan on keeping it past 100,000 miles.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      06-09-2010, 09:19 PM   #9
bmw6953
Drives: 2006 325i
Alot of Indy shops in socal recomend changing lifetime fill fluid between 50k-80k miles. I talked to a few shops and called a few others.
      07-02-2010, 01:48 AM   #10
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
subscribed........
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
      07-05-2010, 01:27 PM   #11
agad
agad's Avatar
United Kingdom
42
Drives: 18' F32 435d M-Sport Plus
do u feel any changes in shifting after replacing the fluid?
      07-05-2010, 02:06 PM   #12
Chriztofor
Chriztofor's Avatar
Not really, still the same as it was before I changed it.
      07-06-2010, 10:31 PM   #13
govtec
Drives: 2006 325xi
There was a mention of changing the transmission filter. Where is the filter located?
      07-07-2010, 12:27 PM   #14
Chriztofor
Chriztofor's Avatar
On my transmission the filter is the pan! Very expensive to replace (about $250.00) see #1 http://www.realoem.com/bmw/showparts...44&hg=24&fg=15
Check realoem.com for your particular transmission/filter.
      08-27-2010, 10:07 PM   #15
govtec
Drives: 2006 325xi
Same with my car. Do you plan on changing the oil pan frequently? If it's just a pan, it shouldn't be necessary to change it unless it is showing sign of wear and tear right.
      08-28-2010, 08:56 PM   #16
bmw6953
Drives: 2006 325i
im replacing mine at 100k just for the hell of it , it cant hurt to change it out.
      08-29-2010, 03:16 PM   #17
Chriztofor
Chriztofor's Avatar
I plan on changing it at around 70,000 miles. It's not just the pan. The pan also contains the filter (pan/filter is one part). Since filters are made of paper I can't see them lasting more than 70,000 miles.
      08-29-2010, 06:21 PM   #18
govtec
Drives: 2006 325xi
it's kind of pricey for the pan itself. I'm thinking about doing the coolant change, water pump, thermostat and filter pan change at once since they are all related. Parts itself will add up close to $1K if I do it myself.
      08-29-2010, 07:18 PM   #19
Chriztofor
Chriztofor's Avatar
I am waiting for the water pump to die before I change it. Especially when it costs 450.00. The good thing is that I have towing insurance from USAA for $12 per YEAR.
      09-01-2010, 12:51 PM   #20
zenmoused
Drives: 328i, Phaeton
I'm doing this tonight to see if it remedies my car shuddering on light acceleration. Has anyone experienced actual positive results after doing this?
      09-01-2010, 08:57 PM   #21
govtec
Drives: 2006 325xi
Post pics and let us know of your experience
      09-02-2010, 09:24 PM   #22
Chriztofor
Chriztofor's Avatar
Well? How did it go? How many miles does your car have? What oil did you use?
