04-03-2010, 05:48 PM | #1 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
H&R springs installed pics
So rake to much? Should I get the 15mm spacer? I know one thing. Red loctite is a moth&^f&c*er, All in all took about 2 hours. Had a tire shop drop the springs into the struts after I removed them from the car.
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
04-03-2010, 08:47 PM | #2 |
23
Rep 374
looks like reverse rake lol
it's interesting, on all the cars ive ever seen h&r's on, they all had more rake on the front. never seen it in the rear and ive seen them on maybe 10 different cars (including a few bmws) they may just need to settle to get to the correct height Last edited by nickpapa; 04-03-2010 at 08:54 PM.. |
04-04-2010, 07:01 AM | #3 |
Rep 1,373
hmmmm... that seems like ALOT more rake then when they were on my car. I just have a couple trouble shooting questions for you.... Could you have maybe put the rear springs on the front? Also did you take both rubber pieces off the stock rear spring and put them on the H&R spring?
07 Z4 M Coupe AW/IR |
04-04-2010, 08:57 AM | #5 |
Dark Sider
129
Rep 1,779
Got front on front, rear on rear. Yep used both spacers in rear. Ill double check everything this morning.
04-04-2010, 09:23 AM | #6 | |
Rep 1,373
04-04-2010, 10:51 AM | #7 |
Dark Sider
129
Rep 1,779
04-04-2010, 02:10 PM | #8 |
Rep 421
Two hours? It took me twice that to do my first corner
Of course it didn't help that I forgot a part and had to take it back apart twice! In your first set of pics the car looked higher than any H&R pics I've seen. The second set looks much more normal. Guess they settled quickly. Still the rear does look a little too low. Does it look that way in real life or just exagerrated in the pics? I think the thicker rear spring pads would make it perfect. Oh yeah, and it's nice to see a modded Sepang. Looks great! |
04-04-2010, 03:08 PM | #9 |
Dark Sider
129
Rep 1,779
Thanks for the color compliment. The only issue I had was the red loctite put on by the factory. I'm going to wait a bit a see if she settles more before I get the 15mm pads.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings Last edited by mousitch; 04-05-2010 at 03:53 PM.. |
04-05-2010, 03:06 PM | #10 |
Dark Sider
129
Rep 1,779
How soon before I get it aligned? Being used springs I'd think I shouldn't have to wait to long. Two wheel or four wheel alignment?
04-05-2010, 03:39 PM | #12 |
Dark Sider
129
Rep 1,779
You mean 4 alignment wheel is a waste? I think that's what you meant. I appreciate the help I've gotten here. No doubt without it I would have been lost. Nice to have this resource and camaraderie.
04-05-2010, 04:16 PM | #14 |
Dark Sider
129
Rep 1,779
Cool. Got an appointment for tomorrow. Went with a local tire shop that has a real good alignment guy. Only thing is that no one around here does the "weighted alignment". Not even my BMW dealer. Anything I need to request as far as specs go, just in case they have never messed with an M?
08-01-2010, 02:48 PM | #15 | |
Booyakasha!
40
Rep 413
Drives: '13 Mini Cooper S Coupe'
Any updates and now that you have the 18x10R Apex Wheels, any clearance issues? I just purchased H&R Springs this morning. Any info/update on your findings would be appreciated!
'08 M Coupe--AW/IR--SOLD!--My M Coupe Obsession
'13 Mini Cooper S Coupe - My Maui Mobile '13 Mini Cooper S Paceman- My Maui 'Stuff Hauler' |
08-01-2010, 03:40 PM | #16 |
Dark Sider
129
Rep 1,779
No rubbing at all. You'll be good to go.
08-01-2010, 05:18 PM | #17 |
Booyakasha!
40
Rep 413
Thanks for the info! Did you go with the 15mm pads in the rear or leave it with the 5mm?
08-01-2010, 08:45 PM | #18 |
Dark Sider
129
Rep 1,779
Left it with the stock pad.I like it. Full tank of fuel. If you don't like the stance you only have to undo the rear wheels and remove one bolt per side to put in the 15mm.
