04-09-2010, 12:34 PM | #1 |
545
Rep 5,695
▀▄ eas | Video Source Module (VSM) for E85 Z4/Z4M
The Video Source Module (VSM) is a video input for integration for a rearview camera or aftermarket products (e.g. DVD player) with the factory navigation System.
Specifications: - 1 Video Input - 1 Camera Input - Auto Video Switching - PAL & NTSC Compatible - Analog & Digital Compatible - Plug & Play Connection - Any aftermarket device attached to this interface will work on the move Kit Contents - Video Source Module - Plug and Play harness - Instructions - Optional Bumblebee camera with forward/reverse image (end user selectable) Reverse bumblebee Camera (optional) Imported overseas from one of the best CCTV Security Surveillance equipment manufacturers in Taiwan, Misumi is well known for applying state-of-the-art CMOS Image Sensor Devices (Camera On A Chip) to the design and manufacturing of security surveillance video cameras. These kind of cameras incorporate high technology used to minimize the size of the cameras and produce a crisp and clear picture quality. The small and indestructible design allows for mounting virtually anywhere on the vehicle without the need for drilling. The "bumblebee" camera gets its name from the mounting bracket that can be mounted virtually anywhere from underneath the decklid next to your license plate or underneath the rear spoiler. This is perfect for newer BMWs that do not feature a keyhole, eliminating the need for drilling. The camera features a 150-degree maximum viewing angle and a 0.5 LUX rating for low light viewing, even in dark areas. Features: - Significantly decreasing power consumption; operates on 3-12V DC - Lightweight - High reliability at low cost - RCA video input - Simple installation - Great for covert use in any place imaginable Specifications: Water Proof (IP67) Color CCD Camera Wide Angle View for Reverse Back Up System Signal System: NTSC/PAL Pixels: NTSC-512x492, PAL-512x582 Image Sensor: 1/4" COLOR CCD Lens: 1.9mm/F2.4 Lux Rating: 0.5 Lux Viewing Angle: 150 Degrees Dimensions: 19x18mm Camera to main board box: 22cm W/Video & Power mixed line (AF-U183) Models Supported: 2003-2009 Z4/Z4M Warning: It is illegal in all 50 states, and in most Canadian Providences, to have real time video (TV Broadcast, VHS, DVD, Video, etc.) in view of the driver. If you are going to use the VSM for anything other than interfacing a rearview camera system, the interlock wire must be properly connected to prevent the driver from viewing real time video while driving. Please drive safe and obey all laws while driving. http://www.europeanautosource.com/pr...oducts_id=2422 Last edited by EAS; 04-09-2010 at 12:42 PM.. |
