04-12-2010, 11:46 AM | #1 |
516
Rep 3,613
▀▄ eas | Macht Schnell - Competition Wheel Spacer kits for BMW
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance. Here is a recent article in European car: -An additional online article in European car's Tech section: http://www.europeancarweb.com/tech/e...gineering.html -Macht Schnell spacer reference thread with photos and spec details: http://www.m3post.com/forums/showthr...schnell+spacer -Macht Schnell DIY on how to properly install spacers: http://www.m3post.com/forums/showthread.php?t=272915 A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders. Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts in black OEM finish. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US. Competition Wheel Spacer kit Features: - Machined from 6061-T6 aerospace aluminum - Chamfered edges allows installation & removal quick and easy - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included black extended-length corrosion-resistant wheel fasteners Macht Schnell - Competition Wheel Spacer kit for BMW - 03mm http://www.europeanautosource.com/pr...oducts_id=2197 Macht Schnell - Competition Wheel Spacer kit for BMW - 05mm http://www.europeanautosource.com/pr...oducts_id=2198 Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm http://www.europeanautosource.com/pr...oducts_id=2199 Macht Schnell - Competition Wheel Spacer kit for BMW - 12mm http://www.europeanautosource.com/pr...oducts_id=2200 Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm http://www.europeanautosource.com/pr...oducts_id=2201 Macht Schnell - Competition Wheel Spacer kit for BMW - 18mm http://www.europeanautosource.com/pr...oducts_id=2202 Models Supported: 2008+ 1-series 1992+ 3-series, including M3 (e36, e46, e90, e92) 2004+ 5-series, including M5 (e60) 2005+ 6-series, including M6 (e63, e64) 2004+ X3 (e83) 2000+ X5 (e53, e70) 2003+ Z4, including M-Roadster/Coupe (e85) 2001-2003 Z8 1996-2002 Z3, including M-Roadster/Coupe All sizes are currently in stock and available for immediate shipment. Last edited by brandon @ eas; 04-12-2010 at 11:58 AM.. |
05-28-2010, 06:39 PM | #7 |
2426
Rep 11,667
Do you do a kit with studs instead of bolts? (12mm)
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
05-28-2010, 08:59 PM | #8 |
8115
Rep 18,808
Drives: BMW
Kits are already prepackaged with matched lugs.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
07-16-2010, 01:21 PM | #16 |
546
Rep 5,695
Improved spacers from Macht Schnell now available!
- Chamfered edges allows installation & removal quick and easy - Machined reliefs on the rear face (10mm, 12mm, 15mm, 18mm, 20mm) which allow easier spacer removal from the hub. - Sizes are marked on the edge for easy identification of spacer size. This is especially helpful when one is running different sizes in the front and rear, and don't want to mix them up. - Machined from 6061-T6 aerospace aluminum - Hubcentric, precision engineered, unrivaled fit and finish - Black anodized finish for additional strength and corrosion/wear resistance - Improve handling by reducing body roll with a wider wheel base - Included zinc-plated corrosion-resistant wheel fasteners Last edited by EAS; 07-16-2010 at 01:35 PM.. |
