Dinan Stage 2 on a Mustang Dyno -- Before and After
05-20-2010, 02:55 PM | #1 |
Rep 127
I did a baseline reading a week ago, then installed the Dinan Stage 2 and the Dinan Cold Air Intake. I originally got 245 HP / 252 Torque. The guy told me that a Dynojet will read 15% higher than his Mustang Dyno. I was generally ok with the baseline (for what it's worth, because of the heat today the machine readjusted the baseline to 241 HP / 245 Torque).
Today I did another set of pulls and I'm only showing 282 HP / 313 Torque. I was expecting in the 315 range, so I'm pretty disappointed. I'm now scheduled to get Stage 3 installed in a week, so we'll see if that helps. The dyno guy said the 3rd run produced 26 less HP than the second run, so the cooling components in Stage 3 will likely help performance significantly. They told me the highest a 335i had pulled on their dyno was 320 HP, so this was within their expectations even though mine were far higher. I'll attach the dyno graph comparison here (I don't know how to paste it inline to a post so I'm using the attachment feature). EDIT: I say it in a post below, but I'll put it here too. The temps were 92 degrees with 50% humidity for the Dinan run. I don't know the humidity for the stock run, but temps were low 70s. Last edited by Cars are the new horse; 05-20-2010 at 04:17 PM.. |
05-20-2010, 02:58 PM | #2 |
25
Rep 374
Hmm what were weather conditions? I dyno'd at like 270 completely stock on a mustang, but it was cold at the time.
Either way its all relative. Good gains there!
05-20-2010, 03:04 PM | #3 |
Rep 127
Thanks, I was expecting more than +41 rwhp / 68 torque, but it *was* hot. 92 degrees, 50% humidity. The temperature at the first dyno was 72 degrees if I recall.
05-20-2010, 03:11 PM | #4 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Sounds really low...where did you take it for the dyno runs? Bavarian Hypersports in NW Houston had a pretty decent dyno a few years back, but I've not been there in awhile. They know their stuff in regards to forced induction and performance mods.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
05-20-2010, 03:15 PM | #5 |
Rep 127
It was a place called Secret Services Auto near the intersection of 59 and Beltway 8 in SW Houston. Nice people there -- they specialize in designing turbos for older cars. I was sure to call Dinan beforehand to verify that dyno runs don't void their warranty.
05-20-2010, 03:23 PM | #6 |
Rep 6,990
I just checked and apparently Bavarian Hypersports has moved to near downtown Houston. They've got a DynoJet, so you might want to look into what kind of numbers you get from theirs if you care to. The numbers you posted looked pretty low, but conditions might have affected them. Kinda hard to avoid the humidity in Houston, though, right?
If the guy at Secret was correct about the 15% diff, you would read 324 hp at the wheels on a DynoJet.
05-20-2010, 03:27 PM | #7 | |
Rep 127
But I think the extra cooling will help especially in Houston. Maybe it's foolish of me, but I'm hoping for 315+ after Stage 3 is installed. I want to try the Dynojet you're talking about, but I also think it's important to go back to the same dyno to measure gains more accurately. I just don't want to go back and pull 290 after blowing Stage 3 money and be depressed. |
05-20-2010, 03:40 PM | #8 |
169
Rep 12,680
Drives: like an asshole
i think those are fair numbers on a dynojet considering the conditions and humidity .
05-20-2010, 03:51 PM | #10 |
Rep 127
You think? I don't know -- I was expecting about 25 more HP and torque to the wheels. Maybe I was being unrealistic, but I actually believed the claimed 384 / 429 plus double digit gains for the CAI.
05-20-2010, 04:08 PM | #12 |
Rep 419
If my math is correct that means you should/would put down about 330 at a dynojet and about 390 at the crank or fly. That sounds pretty accurate with your high ambient temps.
Motegi exhaust, nismo tuned cai, tornado superchager, amg 15" applejuicebox, wheels, spoon body kit
05-20-2010, 04:11 PM | #13 |
Rep 7,377
i had 60 whp over stock with JB3 map 3 completely stock.. seems quite low but you were probably heatsoaking in my opinion.
05-20-2010, 06:08 PM | #16 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
+1
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-20-2010, 06:30 PM | #17 |
Rep 127
What is an IAT? Is dynoing my car hurting it somehow because of this IAT?
05-20-2010, 07:05 PM | #18 |
Rep 2,663
IAT = intake air tempature
05-20-2010, 08:27 PM | #20 |
219
Rep 3,012
The stock numbers look normal to me for a mustang dyno. But a 40 gain from stage 2 Dinan.... Doesn't surprise me in the least. Go buy a JB+ or SSTT lol... You get what you pay for. Perhaps not.
05-20-2010, 09:44 PM | #21 |
///M Uber Alles
332
Rep 1,601
Congratulations for getting a tune that doesn't defeat your engine's fail safe cut-offs when your engine excedes temperature limits. Retest when the temperatures fall back to where they were when you tested stock to get a legitimate comparable.
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
05-20-2010, 09:56 PM | #22 | |
Rep 127
Are my numbers the lowest we've seen for a Stage 2? I'm thinking so (except the Orb fiasco I read about). |
