How to detect meth flow?
05-20-2010, 03:26 PM | #1 |
Cruiser
16
Rep 106
Hi guys,
Just installed my vishnu meth kit but i got a feeling the the meth is not flowing how can i detect if there is meth flow at all? |
05-20-2010, 04:41 PM | #2 | |
Rep 408
You will need to get a flow gauge to know whats going on in real time. Having the monitoring is essential which is why its standard on our flow mapping kits for the procede and JB3. You can order a flow gauge as an add on to the kit you have. Contact Vishnu and tell him you want a flow gauge. CM |
05-20-2010, 04:46 PM | #3 | |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
This will provide the Procede with a flow signal. If it stays at 0, it's not flowing. Also, you can also manually test/prime the pump to make sure it is working by setting the Start psi setting to maximum and the Full psi setting to minimum. This will prime the system for 1 second. You will hear the pump turn on and meth gurgle through the whole system. If you do not hear this, the system isn't getting power for some reason. And we can troubleshoot from there. Shiv |
05-20-2010, 04:59 PM | #4 |
Rep 4,764
What Shiv said. What's great about this setup it the flow signal is going to the procede. It's easy to tell if it is flowing because the Boost PSI you have set for meth will not be reached if it's not flowing.
You can also use the same wire to tap in a flow gauge to put in the cabin if you want, but that's just for extra comfort the way shiv built in the safety once you do the harness update he mentioned. |
