Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Bilstein HD or Sports with Dinan Springs??
      05-25-2010, 11:51 PM   #1
JSLev04
Drives: '07 328xi 6MT
Hey guys,
I'm in the market for a very mild drop on my 328xi and have come across a number of good threads through searches. One setup I liked was the Dinan Stage 1/2. I am however uncomfortable with only replacing the rear shocks and keeping the stock fronts. Would it be feasible to use Bilstein HD or Sport shocks in conjunction with the Dinan Performance Spring set?? This is one setup I couldn't not find any info about when searching. Any advice/ insight would be extremely appreciated. Thanks!
//Josh
      05-31-2010, 04:25 PM   #2
JSLev04
Anyone....Bueller....
Just want to know if this setup would be ill-advised for any reason.
      05-31-2010, 04:43 PM   #3
DJKhan85
DJKhan85's Avatar
Trinidad_and_tobago
24
Drives: 2011 4dr 6mt Golf GTI
why not just buy the bilsteins and then get some other lowering springs?
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD:
08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD
      06-01-2010, 03:30 PM   #4
JSLev04
I personally like the stance it gives, not quite as low as the Eibach Pro or H&R springs i've seen which is perfect for my purposes. Are there other springs that offer a similar drop in ride height while retaining good performance characteristics?
      06-01-2010, 04:46 PM   #5
Joonsup
Joonsup's Avatar
South Korea
322
Drives: E92 M3, E30 325i
2008 BMW M3  [9.50]
i thought the bilstein sports were designed to handle lowering springs whereas the HDs are made for stock heights
      06-01-2010, 04:53 PM   #6
philsteroni
12
Drives: 325xi
I would`nt be surprised if the Dinan springs are actually eibach or H&R springs. Maybe this is something you should consider because Dinan tends to
be very expensive.
      06-01-2010, 05:04 PM   #7
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
OP, you should go with Bilstein sports if you're pairing it with lowering springs. The struts are designed shorter compared to the HD. Also, unless you're getting those Dinan springs at a good price, you're better off with either getting Eibach or H&R sport springs.
      06-01-2010, 05:49 PM   #8
crossover
Drives: on order
Bilstein HD's: stock height up to a 1.00 - 1.25" drop
Bilstein Sports: 1.3" height reduction and lower
Compression and Rebound graphs are identical (HD to Sport) on a shock dynamometer.
Lastly, if it's necessary to go with the Sports don't forget to trim the rear bumpstops accordingly. The fronts won't apply as Bilstein uses an internal bumpstop.
      06-01-2010, 08:08 PM   #9
Gavin@MMW
Gavin@MMW's Avatar
Drives: MMW Supercharged E90 328i
for your purposes, why dont you get some FSD's and be done with it? they can handle the springs and are top quality shocks.
koni yellows are a sportier option if you want the damper adjustability.
      06-01-2010, 08:56 PM   #10
JSLev04
It is my understanding that only the Koni FSD/ Yellow rears fit the XI, which is why Dinan only replaces the rear's with their custom valved Konis on the XI suspension setup kits.
EDIT: FSD**
      06-01-2010, 10:22 PM   #11
MMOTION
MMOTION's Avatar
109
Originally Posted by JSLev04 View Post
It is my understanding that only the Koni FDS/ Yellow rears fit the XI, which is why Dinan only replaces the rear's with their custom valved Konis on the XI suspension setup kits.
You're absolutely correct. Unless you go coilovers, the only strut/shock option you have is Bilstein Sports for XI. I don't think Bilstein makes the HD for the XI's and Koni doesn't have a full strut/shock application for XI either.
