Xede tuning and AWD ?
12-08-2006, 01:54 PM | #1 |
Rep 20
I believe that the 335 will be available in AWD in the spring. Will this tuning system work with the Xi flavour of the 335? I presume that the xi will be slower than the RWD but this tuning enhancement could more than compensate. If currently we are seeing in around 4.4 seconds on a regular 335, what would be the expectations for an xi?
Thanks |
12-08-2006, 02:01 PM | #2 |
Rep 114
The XI should actually have some pretty nice acceleration given the problems with putting down power currently in the 2WD 335. With a clutch drop you should see 4.4 seconds easily... but this can cook your clutch or blow a diff.
As far as handling goes... you will understeer more but if the AWD system is good enough you should be able to control that pretty well just by using different driving techniques. Oh and yes the Xede should work in the XI, but your overall numbers generated will be a little lower due to the additional drivetrain loss. Plus it will need to be tuned on an AWD dyno which is not as common.... but Shiv still may do some EVO and Subbie days where they have to use an AWD dyno, so I am sure you can slot right in. |
12-08-2006, 05:07 PM | #3 |
Rep 5,501
Plus I think it weighs around 200 more pounds than the 335i so I don't know about EASILY doing 4.4 seconds
2007 E92 Montego Blue 335i
