diverter valve removal, plastic grey clips
12-17-2006, 10:47 AM | #1 |
Rep 287
Hey guys,
I'm tring to swap out one of the diverter valves with a HKS valve. But i can't get the dam plastic grey clips off. These are bizare clips that they use instead of regulaar hose clamps. Does anybody know the trick to remove these clips???? Please help. |
12-17-2006, 11:07 AM | #3 | |
69
Rep 3,404
08-08-2013, 11:22 AM | #6 |
Rep 4,088
Reviving this old one bc I'm trying to remove my valves to install a charge pipe and can't seem to get the technique right... the twist lock connector isn't budging!
Is there a special trick to it our just brute force? |
08-08-2013, 11:35 AM | #7 |
Rep 6,478
They can get very gummy, and tough to remove by hand. I used a simple wrench for grip and toque, and gave it a good twist around the grey locking collar. I did this months ago, but don’t recall any issues after that approach. I have no plans to re-use the DVs, but it didn’t damage them or anything like that.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-08-2013, 11:39 AM | #9 |
48
Rep 932
It can take a bit of force sometimes. It sounds dumb, but make sure you are turning them the proper direction.
08-08-2013, 11:42 AM | #10 |
Rep 6,478
IIRC its’ just that grey collar that unlocks when turned the correct way, I don’t remember which way that is though. Just find yourself a bit of mechanical torque/grip and it’ll turn without too much trouble.
08-08-2013, 12:13 PM | #12 |
217
Rep 1,909
If I remember correctly move it counter cw from top ... becareful not to put too much pressure on the pipe itself .. I had to pay to get DPs removed to push in the rear turbo inlet that came half way out because of strangling while airbox removal ... there are no clamps on the turbo end
08-08-2013, 01:09 PM | #13 |
Rep 4,088
Will do it once my car cools off and I get some work done. I think the directions to twist are pretty clear as there is a stop in the twist-lock channel that only would allow the mechanism to go in one direction once locked. Will try some channel locks in a bit and report back!
Thanks all |
08-09-2013, 12:12 PM | #14 |
3441
Rep 79,211
Be careful with channel locks. These should be able to twist by hand and channel locks may put too much pressure and crack them.
I recall giving them a quick push in and then twisting it to unlock. Sometimes pushing it in helps. (Push in, Push out then try twisting). No homo. |
08-09-2013, 12:18 PM | #15 | |
BD_e92
358
Rep 1,748
08-09-2013, 12:31 PM | #16 | |
Rep 4,088
Yeah, I chose not to use the channel locks and just used bare handed brute force (Hulk MAAD!). Everything worked out just fine and the CP-e/BMS pipe is now in there! FWIW the installation instructions CP-e provides are a bit overkill. Don't need to remove the diverters entirely to install them on the new pipe. Didn't want to pull the vacuum hose if I didn't have to. Thanks for the encouragement, fellas |
03-11-2014, 02:09 AM | #17 | |
Rep 450
Fbo stage 3 mmp turbos 100% e85 335i n54 e92
01-01-2016, 12:09 PM | #18 |
The dude abides
50
Rep 265
I've swapping in an ER charge pipe & TiAL valve. The front DV came off very easily, but I'm having a heck of a time getting the rear return line to release - the grey ring closest to the firewall just won't budge. Before I start removing it the hard way, any advice?
There's not room for channel locks on the underside of the ring, and an attempt to use them on the to grab & rotate didn't work. |
