Loosing low-end torque ????
06-25-2010, 10:06 AM | #1 |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
So on Wednesday I had catless downpipes and catless exhaust installed on my otherwise stock N54.
It may be a bit too early to be 100% sure, but it seems to me that the car has lost a bit of its low-end torque. The engine does rev bit faster and feels more responsive, but somehow it feels that it lost a bit of its low-end oooomph. Is it my mind playing tricks with me or indeed the increased exhaust flow reduced the low-end torque of the engine? Any ideas? |
06-25-2010, 10:17 AM | #2 | |
Rep 1,179
more power? was the car performing badly in its stock configuration? but then again, you may have answered your own question |
06-25-2010, 10:51 AM | #3 |
1121
Rep 5,397
No, car ran great before the install and runs great even with the catless system. I went full catless because I want more power. I have a list of mods coming in to supplement the exhaust system.
06-25-2010, 11:31 AM | #5 |
1121
Rep 5,397
06-25-2010, 12:03 PM | #6 |
Rep 91
It is very common to see a loss in low end power when you install a "free flowing" exhaust system. Less backpressure in the exhaust is the reason. It will be much better once you get your tune as timing and boost levels will be adjusted and any loss you feel now will be null and void with the tune.
06-25-2010, 12:27 PM | #7 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Just curious...I heard from a shop that I used for years that removing the catalytic converters was a violation of the Federal emissions standards and could result in up to a $10K fine. Anyone have any other info on that? In some states' annual inspections, they check to see if they are there, others use a tailpipe "sniffer", etc., and in either case, the car won't pass. How are those who choose this path getting by the emissions laws in their states?
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
06-25-2010, 12:41 PM | #8 | |
274
Rep 6,510
The stock boost control system has to adjust to the loss in backpressure. You are making it easier for your turbos to reach their boost targets., so at first you will see the car overshooting its boost target and then pulling boost way back and then it shoots up again... you also get more throttle closure. Some of this will adapt itself out, but you really won't see major performance benefits of catless without a tune. -Rick |
06-25-2010, 12:49 PM | #9 |
Rep 1,184
reduced back pressure is always good for a turbo car even at low RPM
The turbo itself provides the needed back pressure to the engine. So leave it free flowing ! |
06-25-2010, 01:06 PM | #10 | |
Rep 1,179
most cars that have really restricted exhaust systems will benefit from a better (freeflow) exhaust system. BMW tuned this overall exhaust pretty well for stock use. now when you start using power adding mods, this change will be welcome.. and throttle response/torque delivery wont be inhibited by a sub par system. but youll note that most tuners stage one tune is still good for use with the stock exhaust. sounds like you going past that.. right ? |
06-25-2010, 02:26 PM | #11 | |
1121
Rep 5,397
1. HPF Intercooler 2. GIAC Stage 2 or Stage 2+ when available 3. Forge DVs 4. Modded stock intake box 5. LSD Diff + better clutch once the stock one gets toasted |
06-25-2010, 02:28 PM | #12 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
06-25-2010, 06:49 PM | #13 | ||||
Mad tyte EuR0 style boooi <--- Joke
212
Rep 2,472
I just got my emissions tested today. In NC they just check for codes. It depends on your state, I'm sure in California they will ass rape you if you are caught. |
06-26-2010, 01:54 PM | #15 |
Rep 6,990
Here in Texas they will (pardon the pun) cut your nuts off if you get caught without cats after your tailpipe sniff goes off the charts and they start checking for the obvious causes.
06-27-2010, 12:45 AM | #16 |
112
Rep 4,771
06-27-2010, 07:27 AM | #17 | |
The Doctor
14
Rep 170
The gain I saw was like night and day after installing catless downpipes!!
2007 335i: Evolve tune, AR Catless DP, VK FMIC, Vorsteiner lip, VRS CSI bootlid, Lux V3, RD strut bar, P3 Boost guage, PSW, BMW Performance Power Kit, Injen intake - TOTALLED by son
2013 X5M: VRS lip, Velos Tune, Catless DP, Dome hood, electric trailer hitch, performance alcantera SW. |
06-27-2010, 10:41 AM | #18 |
1121
Rep 5,397
I went from stock to fully catless.
