Help Check Engine LIght
07-05-2010, 02:32 AM | #1 |
Rep 104
Hey guys, I am getting a check engine light almost everytime I push my car. When I had Procede V1 the car would run fine and never had a issue, when I switched to V2 I didn't push the car like I did with V1 so I didn't really notice it but I am getting a Check engine light everytime I push the car hard. Could there just be a simple solution? I didn't install the Procede myself, the first time I met shiv in NYC and he installed it. Car ran like a champ, then I had a tech install my V2 and noticed that I would get a check engine light everytime I pushed it hard. Now that the weather is warming up I noticed that it happens every single time I push the car to 7k rpm. Any solutions or ideas?
07-05-2010, 03:02 AM | #2 |
Rep 7,377
probably missfires? check the codes..
07-05-2010, 03:30 AM | #3 |
Rep 408
+ 1 Missfire Cylinder 6 I bet. Try running in Valet mode and go WOT to redline to see if you get a CEL. I would bet you don't. I had the same issue until I had the HPFP replaced.
Procede Inside! AutobahnExotics, Vishnu DCI, AR Oil Catch Can, ETS Black Anodized Intercooler, Quaife LSD, Falken FK452, Mtech 6000k HID, 7000k Halos, 15%vlt Ceramic Tint, Matte Black Kidney Grills.
07-07-2010, 09:39 AM | #4 |
Rep 36
Hey I just started having the same problem how do I get into valet mode to fix it..also I was a little confused by the last post was it a problem caused by the hpfp will I have to get it replaced
Aero front lip|20% tints|RD anel eyes|DCI|JB3 2.0|
19x8.5f 19x10r LeMans| |
