BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Quick JB3 Question, please help!
      07-07-2010, 12:52 PM   #1
07E92TT
Drives: 08 C63
Hey, I know this in the wrong section but i'm having trouble uninstalling my JB3 (my first time doing it). I have to be at work in like an hour and I can't get the sliders to slide back in after the JB3 is out. I've watched the video over and over again but they refuse to push back in. Is there something i'm missing?? Thanks in advance!
Car: 2008 E90 SG/Black/Dark Burl (sold)
2008 MB C63 P.Silver/Black
      07-07-2010, 01:45 PM   #2
Bodie217
Bodie217's Avatar
92
Drives: '10 135i, '14 WRX, '14 Sequoia
I believe you're talking about the plugs that have the slider clips on them, so my recommendation is make sure you have the plugs oriented correctly, and make sure the sliders are in the correct position before attempting to plug back into the DME. The larger (left) of the two connector plugs is more of a pain and i'd install that one first.
Just make sure you don't break the sliders...you can't order replacements.
-2010 BMW 135i - Titanium Silver - Procede v3/ETS 5" IC/AR Catless DP>N54mid>Berk Race/BMS OCC/VRSF Turbo Inlets & CP/SP rotors/Pagid RS29/APEX ARC8/Ohlins DFV/M3 Full Suspension and Bushings/Wavetrac LSD // 395rwhp/469rwtq on 91oct
-2014 Toyota Sequoia Platinum - Overlander
      07-07-2010, 01:47 PM   #3
MusclezMarinara
Drives: VALNCYA
use a screw driver and push the tabs so it clips in.
      07-07-2010, 02:41 PM   #4
07E92TT
Drives: 08 C63
ugh im such an idiot, I just had them connected in the wrong outlets. However the clip that you push in to get the connectors out came off so the connectors just slide in and out with out the clip having to be pushed in. Is this ok? The main slider seems to hold them in not to mention they're actually plugged in to something so they shouldn't slide around....
      07-07-2010, 02:45 PM   #5
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Once you lock the slider in they won't move but just make sure the subconnectors are all the way in before seating them onto the ECU or you might bend some pins.
Mie
