Why is replacing the turbos a 13 hour job?
07-08-2010, 07:29 PM | #1 |
Rep 261
Per the dealer, they say its 13 labor hours.
I understand that you have to take off the skid plate, dps, exhaust, and disconnect the oil system that runs to them, but this doesn't seem like a 13 hour job. What am I missing?
///2007 335i Coupe Space Metal Gray///Sports///Premium///6AT///Piano Black Forgestar 18" F14 8.5" front 10" rear///JB3///Cooling Mist CMGS Methanol Kit///aFe DCI///Stett Chargepipe///Tial BOV///BSH Oil Catch Can
07-08-2010, 07:40 PM | #2 |
Rep 1,035
Waterpump, tstat housing, charge air pipes, coolant lines, expansion tank, manifolds, vacuum lines, oil feed and return lines, etc etc. Plus its a tight fit, stuff is hard to get at. Warranty time I believe is 12.9 hours for both, 17.0 standard time.
07-08-2010, 08:55 PM | #3 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
17 hours times $95.00 (average labor cost in dealerships) = $1615 just for labor!
If you ever have to do this replacement you are better off at an independent shop and buying your own parts.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
07-08-2010, 09:54 PM | #4 |
Rep 3,953
I have seen it done by pulling the motor. Faster that way from what my tech says.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
07-08-2010, 10:34 PM | #6 |
Rep 759
Drives: '11 E92 M-Sport
07-08-2010, 10:59 PM | #7 |
812
Rep 3,974
You are missing the joy of doing it yourself! Try it, you won't feel like they are overcharging when you realize the time it takes you.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
07-09-2010, 06:26 AM | #9 |
Rep 261
I actually was thinking of doing it myself just for the fact that it would be a huge learning experience. The only thing that is keeping me from doing it, is the fear of screwing something up on it. I've got the Bentley manual, a backup ride, a lift and an engine lift. Now I just need the balls to do it myself.
07-09-2010, 07:16 AM | #10 |
Rep 128
07-09-2010, 07:18 AM | #11 |
290
Rep 28,154
its not a quick job, removing all the parts, jacking the engine up, removing the motor mount to make clearance, everything. its not something you are going to want to take on unless you are confident in your mechanical skills, or have a good friend that works for beer and knows his stuff
07-09-2010, 05:10 PM | #12 | |
Rep 932
07-09-2010, 05:29 PM | #13 | |
Rep 1,179
so true.. ive alway wondered why a 2.5 hour medical CAT scan costs a few thousand dollars too .. what the hell am i getting for my money ... i dont even get the spec sheets when they are done -- just a joke.. |
07-09-2010, 05:55 PM | #14 | |
Rep 1,179
if you have never done a job like this expect to double the book time and then add time for additional parts runs for sh*t that happens. a tech doing this for the first time will not, unless he is real good, meet or beat the warranty time, thats why the traditional time guides add 20-25% to warranty time for independent shop.. and remember, the dealer normally has a good stock of ancilliary parts, so if something does go wrong (and it does more often than not) they can walk to the parts counter, pick up the part and continue on with the job. oil lines and fitting dont cooperate, coolant hoses are sometimes difficult to remove and some plastic parts give way to a little more stress than they are designed for. but if you do intend to do the job, talk to someone that has done the job before (recently) and ask for some pointers, and identify all your problem areas (yeah man, i was takin off xx and yy snapped off) learn by others experience and ask which (if any) special tool made the job easier. above all if youre not familiar with the cars engine bay and accessories, take pictures of the assemblies before you disassemble them -- so you will have a refernce point if this takes a day or two to finish... |
07-09-2010, 10:13 PM | #15 |
310
Rep 15,745
I did one set while working for the dealer, and while I was new at it, I had them replaced in 15 hours. When you look at it, it's fairly straightforward, but when you get into it it's all the little bs stuff that eats up the time.
I will be doing an upgraded set come the end of this month, so it should be fun. |
07-11-2010, 09:23 AM | #17 |
Rep 62
Time
I am a Diesel Mechanic the factory sets up how long a job should take. A shop can use other places to get the labor rate such as Mitchelle, or Chilton. But they are close to what the factory sets. The job says 13 hours but if the mechanic has done a few before he will learn quick ways of doing it n may be able to do it under the time. If he does that is money in his pocket because 9 times out of 10 he is getting "Flag" time...
07-11-2010, 09:36 AM | #18 | |
654
Rep 10,587
good post, this is the truth tackle this job on your own only if you have at least a FULL weekend to work on the car, have access to all the tools you'll ever need AND are willing to make runs to a close dealership for parts. you will break things or find that parts are not reusable, it goes with the territory. Go search my build thread to see why i'm saying this, it never works out smoothly.
07-11-2010, 11:07 AM | #19 |
Rep 739
13 hours is a long time!!
It takes evo about 1/2 hour to pull the turbo out. Sometimes, simpler is better!
03 Golf TDI w/ r32 conversion - 120bph/40mpg ftw for now..
06 Evo IX MR - 500whp,,,sold..... |
07-11-2010, 02:12 PM | #21 | |
310
Rep 15,745
I did it a faster way with the engine still in the car and it took 19 hrs total. |
07-11-2010, 02:17 PM | #22 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Definitely not a DIY job unless you have experience AND the right tools. I'd imagine that a lot of shade-tree mechanics will quit half-way into the job
Shiv |
