Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Datalogs showing insane temps - HOT HOT HOT!!
      07-08-2010, 11:04 PM   #1
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
This datalog was taken this past weekend at the Redline Time Attack at Willow Springs Raceway, the big track. Ambient temps were around 95F, track surface temps were hovering in the 120-130F range. A couple of things we can infer here.
-The car is a hair away from going into limp mode due to the coolant temps.
-I need to be using a large meth nozzle or better intercooler, or both.
-Oil temps are not showing up in the datalog but we can make a pretty safe assumption that there were close to coolant temps of 240 deg which is acceptable for this car. Our AR Design oil cooler is doing it's job, the OEM radiator is not.
We need to replace our radiator as it developed a leak in the plastic end tank or we have a leak coming from somewhere else. We've been running the car with just the OEM coolant mix this whole time but now it's time for us to either convert the car over to waterless NPG or 80/20 water/coolant mix. A full battery of temp gauges are also going in the car so we can better monitor the temps when we are out there on the track surface.
And a few pics over the weekend:
      07-08-2010, 11:13 PM   #2
onesuperboi
onesuperboi's Avatar
Drives: '08 e92 335i COBB 4.01 Stage 1
What are your mods and tune?
I think you may consider the AR radiator to upgrade from the stock one. You could also provide some results for us.
http://www.e90post.com/forums/showth...light=radiator
      07-08-2010, 11:17 PM   #3
Overboost
Overboost's Avatar
Drives: Monaco Blue 335i
Damn 183F IATs!!!
      07-09-2010, 12:19 AM   #4
R1000K3
R1000K3's Avatar
Drives: 335i MT
117 C coolant temp
      07-09-2010, 12:24 AM   #5
Ilma
184
Drives: 2008 135i
You should be seeing a yellow warning indicator on the dash when coolant temps hit 248F and the engine shuts itself down at 264F.
You are running really close to that threshold but it's intereting that you only peaked at 242F only that one time......even though you hit the same road speed later on
In daily street driving I see my coolant temps fluctuate around 210-215F.
I think a lot of people who run meth may see lower intake temps, but I often wonder about their oil and coolant temps - looks like you may have answered that question.
Lower intake temps due to meth may be giving a false sense of security that the entire engine is running cooler when it is not.
      07-09-2010, 12:43 AM   #6
benton0311
Lance Corporal
Drives: 08 335i, Graphite
Needs a bigger radiator! Better ventilation for increased airflow through it too.
There was a track test/comparison a few years ago I saw on youtube. I think it was edmunds, not sure. It was a 335i vs a G37 on the track in the summer. Everything was going great for the 335i and it was effortlessly outclassing the G37 in every category. Looked like it was gonna be an easy win and then all of the sudden the 335i overheated and went into limp mode. The nod went by default to the G37 because it didn't break down on the track.
The stock radiator is definitely too small for hard use. I there's also inadequate airflow through the radiator as well as there's really no where for the air to go when it flows through it. Really needs some type of side vent.
So many folks want to upgrade the oil cooler but that's only a bandaid. The real issue is inadequate water cooling.
      07-09-2010, 01:09 AM   #7
lpphreakx06
Professional Moose Racer
lpphreakx06's Avatar
Vietnam
316
Drives: SG 335i E92 RIP + 2015 SS M3
wow, reall nice 1er
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1
|HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM
      07-09-2010, 02:37 AM   #8
BerkTechnology
223
Drives: Fast
Even though the road speed is the same they are on two different parts of the track. It is the long straight that is brutal on the ECT & IAT temps. The same exact thing happens on the same part of the track at the 9min mark on the datalog.
In the other areas of the track map the temps are still very hot, but are not as bad as the 240 deg on that long front straight.
      07-09-2010, 10:14 AM   #9
jblackwell
jblackwell's Avatar
Drives: 335
IAT at 183 just plain sucks.
'08 TiAg E90 335 M-Aero kit. - SOLD
      07-09-2010, 10:18 AM   #10
Ilma
184
Drives: 2008 135i
Lol.....stock cars with the stock intercooler can see close to 150F on sustained runs.
      07-09-2010, 10:26 AM   #11
ar design
ar design's Avatar
Drives: 04 M3
An all-aluminum radiator is a must have if you drive your car hard!
      07-09-2010, 10:31 AM   #12
5soko
5soko's Avatar
333
Drives: M5
Nice update and thanks for sharing!
SO a updated radiator and mix is going in to try to help this problem? What company radiator?
      07-09-2010, 10:52 AM   #13
dzenno
273
Drives:
ar design, do you have graphs like the one above comparing your radiator with stock?
      07-09-2010, 11:01 AM   #14
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
I hope to be able to provide some within short.
I'm currently running the stock radiator and intend to do some laps on the famous Nürburgring on Sunday. Good conditions for testing as it's quite hot right now (more than 30 degrees Celsius). I'll try to log the water temps (as well as IATs and oil temps) for some laps. Next week I'll then have my AR Design aluminium radiator installed and will try to repeat the same testing on the 26th of July at the same location. I'm running meth and have the AR Design additional oil cooler.
Just FYI, E92Fan also had water temps problems on our last Nürburgring trip, but only after (I think) at least 5 consecutive laps when the car went into limp mode. I therefore also think that it's a good idea to upgrade your stock radiator (in particular when tracking the car), also because the stock plastic unit seems prone to leaks (it's not the first time I heard that).
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      07-09-2010, 11:06 AM   #15
dzenno
273
Drives:
do you have this ar oil cooler in addition to your stock or did you replace your stock?
      07-09-2010, 11:08 AM   #16
rismo
Drives: BMW E92 335
To chime in, Im currently dealing with a water pump related issue, (See my thread on the forum) and i'm just back from my dealer.
I asked them about the proper water temp on the system, to their opinion it should be around 114c. Maybe this helps. Bentley states the same as far as I remember.
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3
      07-09-2010, 11:25 AM   #17
BerkTechnology
223
Drives: Fast
We're running a "special" AR Design oil cooler.
      07-09-2010, 11:27 AM   #18
dzenno
273
Drives:
so stock is out?
what about you Alpina? Are you running it dual setup or just the ar oil cooler?
      07-09-2010, 11:30 AM   #19
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Whats interesting and not noted is that those temps are with a hood with all those vents imagine a stock hood.... OOOF
      07-09-2010, 11:33 AM   #20
Clap135
Clap135's Avatar
102
Drives: 2009 N54
You sure the Meth is working? What nozzle?
      07-09-2010, 11:35 AM   #21
Alpina_B3_Lux
263
2009 335i  [8.90]
so stock is out?
I have the stock oil cooler plus the ar design one that is mounted behind the grille.
Alpina_B3_Lux
      07-09-2010, 11:50 AM   #22
I didnt even realize he said hes running meth, now im more confused...
How much boost is he running as well. Eitherway on a road course you are going to need a large tank of meth, I would say atleast 2.5 Gallon and even then im not sure if its going to be enough if you start using larger nozzles.
There is either a flaw in the tank design, air in the line, clog in the line, or an extremely small nozzle being used.
I'm curious about the meth setup as well.
