Meth and Track Racing
07-11-2010, 03:25 PM | #1 |
Modder Raider
753
Rep 8,633
Drives: M3
When I first installed my meth kit and used the windshield wiper fluid tank as my reservoir, there were people that were saying that it wasn't big enough to race on a track. We were considering adding a second tank somewhere just in case.
These are the givens... I am using a 375 ml nozzle which means that it sprays 375 ml/minute. Theoretically, given a 1 gallon tank one should run out of meth after 10 minutes of WOT. Each session length is 15-20 minutes long. Of course, one isn't WOT constantly on a track but WOT is reached most of the time. The wiper fluid tank is approximately 1.5 gallons. When the "low fluid" light comes on then it will take a gallon of fluid. With daily driving, I need to add about a gallon a week. So, for those who haven't seen my thread, I just went to Laguna Seca and had the meth spraying in every session. Here is the thread I started: http://www.e90post.com/forums/showthread.php?t=406907 I was very surprised to find out that I didn't have the low fluid light come on until the end of the 3rd session! The guys at EAS were telling me that I had nothing to worry about originaly since the BERK racing guys run meth at their time attack races but I knew that they were using a smaller nozzle and a bigger tank. They were right though. So, to those who are worried about running meth on a road course and running out, you really shouldn't be worried unless you are using an oversized nozzle, running longer sessions than 40 minutes, or if you are using an incredibly small tank. I really doubt that anyone is doing any of these so you should be alright.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-11-2010, 03:29 PM | #2 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Very good info. How hot does your oil temp get at the track?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
07-11-2010, 03:43 PM | #3 |
Modder Raider
753
Rep 8,633
Drives: M3
I looked down at my oil temp at the beginning of my cool down lap (after 9 hot laps) and it was 250 but I am using the VK oil cooler.
07-11-2010, 04:40 PM | #6 |
NF@ E82
28
Rep 264
+1 great info, thanks
NF@ Jet Black E82 N54
451Whp/448Wtq @19psi; Pump gas & Meth JB3 12 OHM Tuned by: Terry Burger http://www.youtube.com/user/E82jxk |
07-11-2010, 04:55 PM | #7 | |
812
Rep 3,974
Craig, are you using a 50% mixture, or higher?
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
07-11-2010, 05:44 PM | #8 |
Modder Raider
753
Rep 8,633
Drives: M3
Yep, it's 50-50 so when I say a gallon, I mean a gallon of fluid.
07-11-2010, 09:51 PM | #10 | |
Modder Raider
753
Rep 8,633
Drives: M3
I believe the pump they use is a 220 psi pump.
07-11-2010, 10:28 PM | #12 | |
3441
Rep 79,211
Have you any logs of ignition vs Boost by any chance? Most nozzles liters/min are rated at 100 PSI regardless of the pump they sell, just want you to be forewarned. I run a m10 630/ml nozzle but thats rated at 100 PSI, and im at 200 PSI. I also run 17 PSI but my ignition is perfect. Also running 90/10 Meth/water ratio. At any rate my point is I want people to insure they are running safe ignition and the right amount of meth before they start cutting back on nozzle sizes to run track days LOL (not saying you are... just saying though). Last edited by Jeff@TopGearSolutions; 07-11-2010 at 10:55 PM.. |
07-11-2010, 10:39 PM | #13 |
Rep 471
07-12-2010, 12:02 AM | #14 |
Rep 2,408
07-12-2010, 12:15 AM | #15 |
Rep 419
So does a meth system only spray at wot? Is it a voltage triggering system?
Motegi exhaust, nismo tuned cai, tornado superchager, amg 15" applejuicebox, wheels, spoon body kit
07-12-2010, 12:16 AM | #16 |
Rep 1,311
My car consumed 0.8 gallon meth/water fluid per lap at the Nurburg Ring, which takes just below 10 minutes. Max flow in my car is about 700 CC/minute with an M10 and the actual setting of the controller. I was first a bit surprised the meth consumption was so high since I only use about 1 gallon a week for daily driving. A lot of extended WOT on a track change the situation completely though.
End result is the 1.5 gallon windshield wiper fluid tank has enough capacity for any type of driving I do. The volume in the trunk that many use for a meth tank is instead used for a CO2 fire extinguisher. |
07-12-2010, 03:29 AM | #17 | |
Rep 2,559
When I'm there I almost always drive 2-3 laps in a row, and 10-15 laps a day. I'd be a bit annoyed if I had to fill up each time, I have to admit, which is one of the reasons why I went with the bigger tank in the trunk. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
07-12-2010, 04:00 AM | #18 | |
Rep 1,311
07-12-2010, 04:45 AM | #19 | |
Rep 5,175
A side note, a 375 ml/min nozzle does not flow 375 min/min. The Snow nozzles are rated for 60 psi. Since the new SHO pump is rated for 220 psi, you can see why it will flow considerable more. A 375 ml/min at 220 psi should flow about 710 ml/min of fluid. Last edited by Former_Boosted_IS; 07-12-2010 at 09:11 AM.. |
07-12-2010, 10:06 AM | #21 | |
Rep 2,559
Alpina_B3_Lux
07-12-2010, 10:37 AM | #22 |
Rep 5,175
I have dialed in setup to spray 700 ml/min when I am on boost only, then the nitrous activates a second methanol solenoid to progressively inject another 700 ml/min. The second SP methanol solenoid is progressive according to the percentage on nitrous being sprayed. 75% nitrous solenoid open = 75% of the second methanol solenoid open.
