Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > 335i not heating up!
      12-24-2006, 09:17 PM   #1
DowntownBMW
DowntownBMW's Avatar
Philippines
Drives: e92 335i
what are you guys experiencing in terms of the engine temp gauge
it takes my car more than ten kilometers before the needle will move past the 70 degree celcius mark, then it usually stays at 110 degrees ...............range 70-170 deg C
i have a 25 km commute to my workplace, and im almost half there before the temp gauge moves
my old e46 will have the needle by the half way mark of the gauge after a few blocks
anyone know whats going on?
      12-24-2006, 09:19 PM   #2
picus
picus's Avatar
125
Drives: e92 SG 335i Coupe
Same thing with mine, I don't think it's abnormal. Car's don't need to "warm up" like they use to. Turn it on, wait for the revs to settle, and take off. The heater warms up long before the oil temp. Remember, your seeing oil temp, so it'll be slower than the actual engine temp.
      12-24-2006, 09:22 PM   #3
DowntownBMW
Philippines
Drives: e92 335i
ya its the engine oil temp
do you think its bec its a turbo car?
it makes me hesitate to push the car harder
      12-26-2006, 03:15 PM   #4
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
My 325i E92 (UK) is exactly the same. At first I thought the gauge was broken
E89 Z4 sDrive 23i... for the more discerning driver
      12-26-2006, 04:10 PM   #5
picus
picus's Avatar
125
Well they are giving you the oil temp because it's a turbo'd car. The oil just takes longer to heat up, no big deal. Don't sweat it.
      12-26-2006, 04:16 PM   #6
boyce'06 330i
boyce'06 330i's Avatar
Drives: '06 330i Slvr/Gray Prem/Sport
Correct, it's the oil temp. There is not a water temp gauge (the gauge you're used to) on these cars. Oil takes much longer to heat up than water, also and may never show "warm" like you're used to with the old water temp gauge. In my A6, the oil temp would barely register heat unless I was cruising on the interstate.
      12-26-2006, 05:38 PM   #7
DowntownBMW
Philippines
Drives: e92 335i
ok boys, thanks
now that makes more sense!
i didnt know it was water temp gauge i was looking at in my old e46, as i mentioned, it warms up quickly after a a few blocks!
      12-26-2006, 05:56 PM   #8
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
yes, on the z4 its a water temp gauge as well and rises fairly quickly.
      12-27-2006, 11:30 AM   #9
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
FWIW...
The Z4M is oil temp as well.
Very slow moving.
Z4M also have LED warm up indicators on the tach.
IIRC they're base on an algorithm of outside air, water & oil temp.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
