Vin # for the N54
07-19-2010, 01:03 PM | #1 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Vin # for the N54
Don't want to go off-topic on another tread so started this one instead. Want to get info on cars with N54 engines.
So you're saying that a 3 series could have the same sequence as a 1 series with just the last 3 numbers different? Wouldn't BMW have a range for each model they assemble?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
07-19-2010, 01:17 PM | #2 | |
The Stig
31
Rep 1,232
07-19-2010, 01:31 PM | #3 |
Rep 2,663
But car manf. usually recall cars with specific vin number ranges. So therefor, they can distinguish what model car from the assembly and built date.
07-19-2010, 01:48 PM | #4 |
Rep 1,179
quick breakdown
the fourth and fifth digits in the VIN are the platform identifier..
as follows WB = 3series coupe WL= 3series convertible two additional digits on the AG code identify the type within the series 73 = 335 33 = 328 but since the full VIN sometimes follows the above convention, the sixth and seventh digits dont alway correlate -- sometimes yes, sometimes no.. . such as WBA*WB73* the manufacturer will base there information on the fully decoded VIN not just the last seven .. cheers |
07-19-2010, 01:51 PM | #5 |
The Stig
31
Rep 1,232
Then see if you can find some data to describe the ranges for BMWs...I haven't looked. You may be right.
Still, for the purpose you're considering this for, the main issue will be whether or not it is worth it to store a lookup table if the serial numbers are spread apart.
07-19-2010, 01:52 PM | #6 | |
The Stig
31
Rep 1,232
07-19-2010, 01:57 PM | #7 | ||
Rep 2,663
Where did you get this info?
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS Last edited by AltecBX; 07-19-2010 at 02:03 PM.. |
07-19-2010, 02:13 PM | #8 | |
Rep 1,179
if you need any further help with vin stuff.. id be glad to help out... Last edited by shifterboy45; 07-19-2010 at 04:26 PM.. |
07-19-2010, 06:52 PM | #9 |
Rep 2,663
07-19-2010, 08:32 PM | #10 | |
stick to your guns
20
Rep 441
Bentley Manual, they're $80 on Amazon
"Speed has never killed anyone...suddenly becoming stationary, thats what gets you."-Jeremy Clarkson
07-20-2010, 02:01 AM | #11 |
Rep 2,663
Does this come in PDF format? If so, anyone knows where to download it from?
07-20-2010, 03:24 AM | #12 |
Rep 7,377
you have to buy it. i already tried to find a torrent some time ago but did not succeed
07-20-2010, 08:42 AM | #13 |
stick to your guns
20
Rep 441
it's definately worth the money, especially if you plan on installing mods or doing maintenance yourself
