BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB3 2.0 occasional low boost Error Code
      07-21-2010, 09:11 PM   #1
stikya
stikya's Avatar
24
Drives: 2024 BMW M3 Competition Xdrive
I don't think this one has been described yet....Ran JB3 1.4 (map 3) for many months no issues.
Within 1 week after I installed the JB3 2.0 (map 3) update chip, I started getting an occasional "low boost" error code: engine malfuction, 1/2 power. I don't have the exact code.
It happens sporadically, but always when I accelerate very slowly from any cruising speed.
for instance I was getting on an on-ramp behind traffic and was poking along, I push the accelerator just slightly to speed up, at about 20-30mph and as I begin to accelerate, slowly to 35, it comes on.
also happens as I'm coasting around a curve, say going 60, and hit the gas gently.
Under hard excelleration I have no issues.
thoughts?
2024 M3 Comp. X-drive, BSM + Kavaca stealth PPF
Mods: Vorsteiner grille, MHC+ CF skirts & badges, MAD mid-pipe & SST valve controller, M.Perf. splitter.
      07-21-2010, 09:22 PM   #2
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Do you have access to a BT cable to get the car scanned? Does it happen on map0 or any other map?
Mike
      07-21-2010, 09:26 PM   #3
stikya
stikya's Avatar
24
Mike
I don't have access to a BT. I can go to a shop and get an ODBII scan.
And it happens so rarely I've not tried another map...only map 3.
I'll try map 0 for a few days and see.
      07-21-2010, 09:35 PM   #4
stikya
stikya's Avatar
24
along the same lines...
Mike
Since JB3 is controlling the ECU does car really go into 1/2 power mode? And if so, does driving it hard or for an extended period in 1/2 power mode do any damage to the car.
Sometimes I can pull over right away and restart.
      07-21-2010, 09:45 PM   #5
Mike@N54Tuning.com
4918
If its coming up at light throttle update to the 7/4 firmware, they made some changes in there to accommodate various ECU versions. And if its at WOT then you need to raise the min or max target setting. Either way email me or BMS a scan of the code/freeze frame data and we will let you know what to adjust.
Mike
      07-21-2010, 10:04 PM   #6
ridin135
Drives: Depends on the day
contact terry by email he will respond before you send it. He will try and get it all cleared up for you.
      07-21-2010, 10:19 PM   #7
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
this
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
      07-22-2010, 11:29 AM   #8
stikya
stikya's Avatar
24
Mike
definitely at light throttle.
I'll follow up with Terry. Thanks.
      07-22-2010, 11:41 AM   #9
02themax
02themax's Avatar
28
Drives: E90 335i
Sounds like the 30FF code, just scan and reset if it is.
E90 335i
Sport Package - Logic 7 Sound w/ipod - Bluetooth - Comfort Access - PDC - 19" M3 Reps 275/30 235/35 - Blacklines - 10mil spacers rear, 5mil spacers front - BMW Alarm
      07-22-2010, 02:34 PM   #10
stikya
stikya's Avatar
24
I believe that's correct, based on the description the guy who cleared the code gave me.
Resetting is getting annoying.
I guess the new 7/4 firmware update will alleviate the problem. So, I'm going that route. I'll report back.
      07-22-2010, 02:39 PM   #11
stikya
stikya's Avatar
24
Mike
Do I just need to buy the USB cable to do the 7/4 firmware update? I don't have the chip burner.
Also, will this allow me to update the chips when new versions come out?
(Excuse my ignorance I'm pretty new to the BMS products.)
      07-22-2010, 05:50 PM   #12
335iSSA
Poland
15
Drives: 07' E92 335i
It may not be related to the JB3 at all. I'm completely stock and had this happen a few times on a road trip. With the BT it was the 30FF code. Took it to my dealer as soon as I got home. They couldn't figure out what the problem was and just wanted to update my software without knowing what the issue was... Given that I am on the original software (07 build) I wasn't going to turn my car into a laggy turd and declined them to do anything. Just figure I'd wait till something takes a crap and then they will know what to fix. Good luck.
      07-22-2010, 06:04 PM   #13
stikya
stikya's Avatar
24
It's possible it's unrelated..but given the 1st erorr's occurance was a couple days after the 2.0 chip update, I find it very unlikely.
Either way the firmware update will be useful, so I'll do it.
Thanks for the input.
      07-22-2010, 08:23 PM   #14
Hit_Apex
Riding the knock sensor
Hit_Apex's Avatar
2371
Drives: 21 X5MC | 23 M4CSL
2021 BMW X5MC  [0.00]
BMS customer service is exponentially more effective at addressing support issues than can be elicited from the public in an online thread.
      07-23-2010, 09:17 AM   #15
Mike@N54Tuning.com
4918
Yes with the usb cable you can flash this and all future versions.
Mike
      07-23-2010, 09:57 AM   #16
Clap135
Clap135's Avatar
102
Drives: 2009 N54
Before you buy stuff to update make sure you have the right board that allows this.
