The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > fitted dp fix, SES light still on.
      07-25-2010, 12:47 PM   #1
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
I fitted my dp fix today and cleared the codes with my bt cable. drove the car for 5 miles and the light came on again, checked the codes again ans they said back lamba sensors after CAT.??????? do i need to adjust the dpfix??
      07-25-2010, 12:58 PM   #2
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Are you sure your sensors are not damaged?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      07-25-2010, 01:10 PM   #3
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
yeh the sensors are fine as far i know. its only been since i fitted the dps. sensors had to be relocated slightly higher as the dp i baught were for LHD and mine is a RHD as i live in england.
      07-25-2010, 04:35 PM   #4
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
what fault codes come up wen the dp's are fitted as i asumed the lambda sensors would be the ones, i was thinking of adjusting my bms dp fix to 3oclock or 9oclock does anyone know if this will work. any help would be great as im not sure if the problem is that.
      07-25-2010, 04:46 PM   #5
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Which o2 sims are you using and what code did you get exactly?
Mike
      07-26-2010, 05:17 PM   #6
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
codes..
2F6C exhaust fume flap
2CA9 Lambda probe heating behind cat 2
2CA8 Lambda probe heating behind cat 1
I Have just cleared codes again and reset lambda on the command section of the BT software.
I have the adjustable BMS DP fix so not sure which setting to put it on
Any advice would be appreciated.
      07-26-2010, 05:24 PM   #7
Mike@N54Tuning.com
4918
Originally Posted by mikey335iT View Post
codes..
Those are not DPFIX codes. Maybe you just connected it wrong? Email me some photos if you want me to double check.
Mike
      07-27-2010, 11:17 AM   #8
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
hi there typical as it has been raining all day today so i cant get to the ecu to take pics until tomorro, but when wiring up the DP fix i was left with a black male wire and it didnt say wat to do with it so i just taped it up?????? i am not using a JB3 my 335i has been re-mapped so its being wired straight to the ecu. any help would be great as this light is doing my head in, i keep clearing the code then after maybe 5-10 miles it comes back???
      07-27-2010, 11:50 AM   #9
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
are you running stock exhaust with the flap vent unplugged? that is what the first one is
      07-27-2010, 12:06 PM   #10
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
yeh im running the stock exhaust with it disconected in the boot, but would that cause the other 2 codes??? i assumed that as im running with no CATS i may aswel disconect it, i was told the fume flap was there to warm up the CATS quicker??
      07-27-2010, 12:25 PM   #11
mkiv
2JZ
63
Drives: 16 G500
are you missfiring?
E92 335i Fully Loaded | Procede Rev2 | ETS FMIC | AR Catless DP | AFE DCI | AA BOV | KW V2 | iForged Essen | VRS CF Trunk | M-Tech Sideskirts | M-Tech Rear | Ericsson Front GONE!
      07-27-2010, 02:25 PM   #12
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
yeh it was miss fireing the otherday but since i changed the HPFP and installed the dp fix it has been running ok. just a light on the dash. confused???
      07-27-2010, 02:29 PM   #13
Jonny550
Jonny550's Avatar
241
Drives: 2012 550i Xdrive
same here bro.
[SIGPIC][/SIGPIC]
      07-27-2010, 04:00 PM   #14
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
Originally Posted by Jon335iFL View Post
same here bro.
are you havin te same problem jon??
      07-28-2010, 12:51 AM   #15
Jonny550
Jonny550's Avatar
241
I donno if iam throwing that lambda code but iam throwing some kind of CAT code. Iam sure its because of the DP fix. I installed my downpipes and then my 02 sim and the car ran without a SES light for a week, then it popped up and i cleared it,2 days later it popped up again and i never even bothered trying after that. However i could have the SES due to misfires also.
[SIGPIC][/SIGPIC]
      07-28-2010, 04:59 AM   #16
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
Hi jon I've realized I fitted the dp fix wrong as I was left with one cable left which I assumed was for the JB. I will be fitting it properly on my lunch break so I'll take pics an update later, I left the light on and didn't clear the code last night an it started fine this mornin so the miss fire has gone after replacing the HPFP, I was told it was mis firing In the mornin because the pump had no presure.
      07-28-2010, 12:58 PM   #17
mikey335iT
mikey335iT's Avatar
England
11
Drives: bmw 335i
2007 335i  [0.00]
so i think ive sorted out my problem i hadnt conected one of the male black cables to #19 yellow cable so that was probably the cause, so far ive had no SES light come back and i have a clear dash board for once. lol. im hoping my problems fixed and the car is running so much better now, No Smoke pouring out the exhaust, power feels better and its idling better, just shows wat can happen if you dont double check things. thanks for the help everyone
      08-10-2010, 01:13 AM   #18
0shit
0shit's Avatar
Drives: C7/720s/M8CGC/BroncoWildtrack
You mentioned "No smoke pouring out the exhaust", did you have white smoke coming out especially when you would come to a stop? I'm trying to figure out my issue I had, simple fix was to re-install the cats to the exhaust. Cleared the codes, and after a few days the SES came on tonight. I couldn't take the smoke pouring out so, hence; the cats going back in. I installed a PROcede but that didn't help either to solve the "pouring smoke" issue.
Thanks,
RIP: Snohman.. Great friend, great father, and we'll never forget your selflessness.
