335i BOV "map sensor"?
12-30-2006, 11:22 PM | #1 |
22
Rep 579
Shiv said that the 335i uses a "Map sensor" rather then a "Maf". Is this true? If so, this means having a Bov shouldn't cause any problems. Can anyone confirm?
12-30-2006, 11:41 PM | #5 |
69
Rep 3,404
check these threads out and make your own decision...
http://www.e90post.com/forums/showth...light=335i+bov http://www.e90post.com/forums/showth...light=335i+bov http://www.e90post.com/forums/showth...hlight=335+bov theres more you just have to look |
12-31-2006, 12:45 AM | #6 |
22
Rep 579
Thanks for all the links, however I have seen them all. Alot of the threads only tell you how the car would sound and others just claim that there will be no problems. I guess I'm just being Naïve but I need proven facts. Thanks for your help though. Anxiously waiting the arrival of my 335i. 37 days and counting.
01-05-2007, 11:29 PM | #7 |
Rep 1,417
From what I have read on forums, this sounds like a good explanation.
On other turbocharged cars, most have BOVs that go back into the intake chamber. Some ECUs know this (with sensors) and expect that extra air, the 335i apparantly ignores it and has no sensors. The extra air that the car would get would be hot and uncompressed anyway so it won't matter much either way. I'm not sure 100% I worded everything correctly, but I think it's close |
01-07-2007, 11:28 PM | #8 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
I can't see how a BOV would be a problem with a car with a MAP sensor. If the 335i had a MAF sensor then it would make sense to me. Cars like EVO's and STi's have problems with BOV's since the ECU with a mass air flow sensor is expecting that extra air when you let off the throttle, but cars with MAP sensors shouldn't care.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
01-08-2007, 04:55 PM | #11 |
22
Rep 579
Shiv told me that the 335i runs on a MAP sensor, however Calvin@Vishnu claims it's on a maf sensor. I definitely believe shiv over calvin but it gets confusing. Would it be wise to install a BOV? I love the sound of it. Turns chicks on......
01-09-2007, 03:41 AM | #14 | |
Rep 7,719
You guys will find that VTA BOV gets annoying after a while since everytime you release the gas pedal, it will sound. The whole reason to upgrade the BOV in the first place is to hold boost better, even Shiv said that the stock holds boost with no problem, I see no reason to upgrade...unless you want that ricey sound. |
01-09-2007, 11:28 AM | #15 |
Rep 101
Drives: F07 535 GT
Garage List 1961 HUMBER HAWK [0.00]
1995 M3 [0.00] 1988 sierra sappire ... [0.00] 1978 rangerover [0.00] 1967 Mercedes 200 [0.00] 1967 Unimog s404 [0.00] |
the factory dump valves sound just the same as any other dump valve if you disconnect the outlet and plug the pipe it went into. I think the 335i engine uses a Mass Airflow Sensor AND a Manifold Absolute Pressure sensor, in fact i believe it has 2 of the latter, one before an done after the throttle butterfly. Lots of people have firred aftermarket Dump valves, and it doesnt seem to cause a problem, maby the super smart computer can still run the engine fine without the extra air from the dump valve going back through the intake system.
535GT
01-09-2007, 12:54 PM | #16 |
Rep 6
My turbo VW's had a diverter valve which needed to be upgraded as more than factory boost was applied, I went with Forge diverter valves and never had an issue.
Not sure what kind of sensors VW's had but people that installed BOV's had issues with check engine lights. I hope I never hear a 335i with a BOV - so ricey.
2007 335i Arctic/ Terra 6 Speed Sport Premium Sedan |
01-09-2007, 02:20 PM | #17 |
84
Rep 1,575
Dont use BOVs. This car must sound like a BMW and not like a cheap worthless honda!
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
01-09-2007, 02:40 PM | #18 |
22
Rep 579
Sorry guys, but I love that sound, everytime I ride with a chick and they hear a turbo spooling witht he BOV, they LOVED it. Might sound ricey to ya, but I love that sound.
01-09-2007, 08:20 PM | #19 |
Rep 287
The 335 has 2 map sensors.
1 before the trottle body the combines presssure sensor and temp sensor. And 1 in the intake manifold. Also since the sensors are located after the diverter valve, if we where running a MAF the sensor would read the flow after the BOV open and would fuel the motor according to the accurate air flow. In this situation the MAF would be called a blow thru MAF. See pics of the 335 air induction overview Look at nubers 8 & 11. I also added more info on th efactory BOV. |
01-09-2007, 09:08 PM | #20 | |
Moderator
132
Rep 6,775
-Michael.
01-09-2007, 10:07 PM | #21 | |
Rep 423
01-10-2007, 08:29 AM | #22 |
84
Rep 1,575
You becoming too serious !!! Just kidding guys.
We have a BMW and we got to enjoy it sometimes. I also have an Opel Corsa 1.2cc ...so what? Give me a break... Just for your info (cause you called me Ignorant)...I may be a BMW fan and had many BMW along the last 10-12 years ,but keep in mind that my second favorite car is 350Z (a Nissan!!) and my dream as a new driver was to own a CRX (and later an S2000). On the way ,I may bought BMWs but the truth is that I respect Honda.
