2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding satellite radio reception
      08-01-2010, 06:10 PM   #1
ilsb
Drives: 2011 535i
Does anyone else have issues with frequent "acquiring signal" with Sirius sat radio. Sirius says it is a BMW issue and dealer is not aware of any issues. Only started in last 2 days.
      08-02-2010, 04:55 PM   #2
MikeTerp
Drives: 2016 F30/340
Nope, mine works fine. Now, there are occasions when I am going under overpasses or underneath lots of trees where the radio will lose lock on the satellite, but for the vast majority of times I have no problems. If this continues, have your dealer check the leads from the sharkfin antenna to your radio as part of the diagnosis. You are not so far north that you should have any significant issues with low elevation angles to the satellite over the equator.
      08-02-2010, 05:33 PM   #3
ibimmer954
Drives: '23 i4 M50, '15 M3, '18 911
I haven't had any unexpected issues with my Sirius radio reception. Sure, driving underneath a bridge will cause it to drop signal. But other than that, it has been solid. There were supposedly issues on the 3-series models during the last year that were causing problems with Sirius. Maybe someone is confused about that. I haven't heard about any issues on the 5-series so far, and mine has been fine.
      08-02-2010, 08:04 PM   #4
Gsquared
Drives: 2011 550i
Mine is solid as well no dropped signals except underpasses etc
      08-03-2010, 07:03 AM   #5
ilsb
Drives: 2011 535i
Thanks for the comments. Looks like I could have an issue with the car. Was fine for the first week then all of a sudden am getting frequent (every 10 seconds) acquiring signal message. Going to have dealer check it out.
      08-03-2010, 10:30 AM   #6
listerone
Drives: 2018 BMW 540d
I get very good reception about 98% of the time.Occasionally,when driving on the Mass Pike west of Worcester (for example) I get brief dropoffs when going past those rock "cliffs" you see.I've always assumed that it was because the "cliffs" block the antenna's view of the southern horizon which is essential for satellite radio.Anything that blocks that view...hills/mountains/cliffs,tall buildings,etc...can cause dropoffs.
Current : 2018 540d
Formerly: 2014 328d
Formerly: 2011 MB E350 Bluetec
Formerly: 2009 335d
      08-03-2010, 10:57 AM   #7
Bimmer5
Bimmer5's Avatar
Drives: 2020 X3M
Have not had any trouble with mine
      08-03-2010, 07:27 PM   #8
blulite
Drives: 2011 550i
No problems for me.
      08-04-2010, 08:57 PM   #9
SD535
Drives: 2011 535i
Hey ilsb,
Greetings from FH. I mostly listen to library on my iPhone with the connector, but when my wife took my car with my daughters they were all over the radio function... They told me that I have a stupid car that can't get a good radio signal... they didn't really get that satellite was satellite, since we never had that before.
I have tried it over past week and have gotten alot of dead moments ( just a brief pause, not "Acquiring signal"), but you know that there has been an increase in cloud cover recently...
I have always steered away from satellite anything, for fear of losing signal during clouds or weather. There are some "hills" in Feeding Hills so I am not sure if they impede the signal...
Ill be interested in what NC tells you, as I would bring it in if turns out to be anything substantive...
SD
      08-05-2010, 08:34 PM   #10
ilsb
Drives: 2011 535i
Hi SD535,
Sat radio was working fine for first week. Last Saturday noticed lots of drop out around O'Briens corner and Sarat Ford area down to Agawam center. Never got this before. I am taking it in to Gingras in WS next week to have them check it. It appears to be a loss of sensitivity. In my 08 never got the drop outs I am getting now.Could be a Satellite thing but I doubt it. Let me know if you get drop outs from Sarat Ford to center of Agawam next time you take that path please. I am curious as to how your sat radio performs in that area. You can email me at ils@ilsmail.com if you wish.
Thanks
      08-05-2010, 09:13 PM   #11
kscarrol
kscarrol's Avatar
Drives: 2021 X3 M40i, 1974 2002 Tii
Seems a couple of folks in Mass are having issues. Sirius uses ground based repeaters to avoid drop out in major population areas. Perhaps they are having some issue with that system in the area. I get the very occasional drop out in my 2008 550 but have not been listening to Sirius recently. I'll try it out tomorrow and see if there are any issues.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      08-09-2010, 12:11 PM   #12
ilsb
Drives: 2011 535i
Well, magically my Sat radio is now perfect. Obviously, Sirius had a problem that they were not admitting. After one week I went from frequent acquiring signal to NO drop outs at all starting Saturday. They obviously fixed their problem (or maybe they launched a bunch of satellites).
      08-09-2010, 08:57 PM   #13
MBrown1003
Eight Bimmers and counting
Drives: 2014 F10 M5
I also read about intense magnetic storms last week due to solar activity. (There was a chance of seeing an aurora as far south as the northern US states.) I *think* that also affects satellites (hence problems with both satellite radio as well as GPS).
2014 F10 M5
Previously...
Threes: '08 E90 M3, '07 E92 335i,
Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i
Others: VW, MBz, Peugeot, Toyota, Olds
5post
