Half throttle misfire
08-01-2010, 09:03 PM | #1 |
17
Rep 310
My car has recently been having a part throttle(partial boost) misfire but runs fine at idle and WOT. it seems to only misfire at about 3-4k rpms under part thottle. I have no idle issues and the car starts fine. any ideas?
2007 AT with 72k with a new engine block and pistons 10k ago. running jb3 and dci, does it with the tune and without. Any ideas will be appreciated. i got a cylinder 4 misfire code once. |
08-01-2010, 09:37 PM | #2 |
Rep 1,193
swap plug from cyl 4 to another cylinder and see if it still misfires on cylinder 4. If it does just change the plug or change all 6 for good measure. If not may be a coil pack or injector. Why the new block and pistons? Motor blew?
08-02-2010, 12:43 PM | #8 |
Rep 1,155
Stock :\ Do you drive long distances? I have a feeling my daily driving of 40 miles at 2000rpm is screwing with my adaptation tables. It feels like the car is running lean around 2500rpm.
08-02-2010, 12:50 PM | #9 |
17
Rep 310
it started happening after 8 passes down the quarter mile... in one day..........at cruise-70-80 it runs fine. only when i accellerate at half-ish throttle. but ill be sure to let you know.
08-02-2010, 01:22 PM | #10 |
Rep 1,054
I have this problem since new fuel pump, software, and fuel injectors....
I have had misfires in 1, 2, 3 and 4. Replaced fuel injector #1 and still having regular misfires in #2. Right now... the misfiire has been following the injector when I move it. Bringing it in tomorrow...
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
08-03-2010, 05:05 PM | #11 |
17
Rep 310
i put in some techron concentrate with about 5 gal of fuel , drove for about another 100 miles and i cant get it to misfire today.......im going on a 900 mile trip thursday and will let you know if it comes back.
08-04-2010, 08:36 AM | #13 |
17
Rep 310
if anyone is looking for injectors.....heres some dirt cheap!
http://cgi.ebay.com/ebaymotors/ws/eB...category=33554 |
08-07-2010, 03:14 PM | #14 |
Rep 1,155
Received a call from the dealer on Friday saying they have a new software update for the misfires from the new flashes. I dropped my car off and they said the problem is cured, but they want to hold it tell monday (they don't work weekends) and make sure it has no cold start problems.
Michael |
08-16-2010, 12:12 PM | #19 | |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
What happened to the first engine? Maybe this could give us a hint as to the source of the current problem. Last edited by OpenFlash; 08-16-2010 at 12:18 PM.. |
08-19-2010, 07:27 PM | #21 |
17
Rep 310
the first engine had some kind of cam issue and was bucking like crazy, then one day after i picked it up, i accelerated to test it and it threw a rod.
today i noticed that my misfire is only at lower rpms 2500-3500 with a high load. like if im doing 40 or 50mph and put it in 5th gear and accell all the way b4 the clicker it will misfire. but at WOT and high rpms its fine. i got a cylinder 6 misfire twice today...:-( |
