2010 E90 328i Sound System/Speaker problem.
08-12-2010, 01:11 AM | #1 |
68 Time Gold Medal Champion
22
Rep 75
Hey guys, so my '10 E90 328i has this problem with the sound system, the volume seems to be limited, i cannot raise the volume to its maximum potential. And when i do raise the volume to the max it goes, the speakers begin to make these cracking noises and cut off the sound. Its very irritating. I took it to my local dealer, and the worker told me that several people have came in with the same problem, and they cant do anything about it. Is anyone else having this problem? He also told me 2010 328i's do not come with amplifiers. My car is base model btw, no upgraded sound system. Just wanted to know if i was alone in this situation.
2010 E90 328i (daily driver)
2007 Mercedes-Benz CL550 (weekend cruiser) |
08-12-2010, 01:18 AM | #2 | |
109
Rep 1,830
08-12-2010, 08:31 AM | #3 | |
2304
Rep 13,009
BMW uses a crappy IC amp in the OEM HU/iDrive when configured for the MY2010-11 Stereo system. Because this system drives the speakers directly from the OEM HU, when you max the volume it simply cuts power as it cannot move all 6-speakers with just a max of 15W for only 4 speakers. This system was installed as standard for exactly one year (09/09 to 09/10) and from September production on a separate amp in the trunk (and 8-speakers) will be again standard. |
08-16-2010, 05:08 PM | #5 | |
Rep 114
WWONG, how much did the upgrade run you and where was it done? |
10-19-2010, 07:16 PM | #7 |
Rep 515
Where can you upgrade to stereo at? I have a 2010 328i sedan with base stereo coming from an E92 335i coupe with Logic 7 and stereo sounds ok on the 328i but I miss the Logic 7 or better sound from my 335i coupe.
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
10-19-2010, 07:24 PM | #8 |
2304
Rep 13,009
You can have a better Logic7 system in your E92 if you add a MS-8 to it.
07-20-2011, 01:17 PM | #9 | |
Rep 1
07-20-2011, 04:28 PM | #10 |
Rep 3,201
Have you tried turning the Logic 7 off and seeing if your "fluctuation" stops? Because if you are describing an actual amp issue, it won't go away by installing a new amp, because the L7 amp is also the optical-digital-to-analog converter.
